Question about NRS Garden
I was given a Case tractor. It needed a fuel
I was given a Case tractor. It needed a fuel line. I replaced the fuel line. I can't get the tractor to start. It will turn over all day long, but wont catch. please help
    Scholar:
  • 108 Answers
Is your fuel pump working? are you getting fuel to the carb?
1. check for spark
2. check for compression in all cylinders
3. check carb (if it's been a long time since it was last started, you will need to just take the carb apart and clean it or get a carb rebuild kit. rebuild kit is easiest route and once you do that, you are done fussing with it.
4. Diagnose the problem.
a. try starting fluid directly into the carb. If it fires up then quits you have a fuel delivery problem. Once you figure out that, you can trace the problem back from the motor to the tank.
5. If you don't have any spark, try new plugs, then try new wires, then start going over your electrical system
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Posted on Oct 05, 2009
Case 7130 Tractor stas running then quits
I had a close to that problem and decided the fuel was the problem,So I added a electric fuel pump between the fuel tank and the manual fuel pump,,but also check the fuel line between the fuel pump and the fuel tank,for it may plugged with dirt or the manual fuel maybe to weak to the job ,so I added electric fuel and the no more problem with air locks or no fuel to keep the tractor running.
Jun 04, 2014 | The Times Case Corporation Tractors...
Husqvarna 42" Yard Tractor YTH1542XP rear fuel line leak
Been looking the parts diagram, it shows 1 line on the tank. Need to replace line.
Nov 24, 2013 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Ih tractor
You will need to bleed air from the injector pump it self. Next to test glo plugs pull from engine and connect a wire to the body to the earth. Turn on ignition and press button for a few seconds and they should glow. If not check for power to the plug
May 06, 2013 | The Times Case Corporation Tractors...
Yanmar diesel fuel injector leaking
If you removed your injector lines, and then reattached them. You first off got air in the line and you will have to purge them. But, I believe that your injector gasket was probably the culprit and why it was leaking. It sounds like the injector was losing fuel pressure and the pump was unable the push enough fuel to all the cylinders when under load.
If it were me, I would go online to HoyteTractors.com they carry every part for your Yanmar tractor that you will ever need. They also have a tech department too. Since you already have air in your lines, you might as well replace the fuel filter and O-ring and injectors seals. You can also get a service manual from Hoyte for your specific tractor model. If your Yanmar (3000) is like mine, my fuel pump is on the "passenger side" of the tractor and it has a bleed valve on it. So after you replace your parts you can bleed the air out. They are very simple machines to work on. Just in case you didnt know, most Yanmar tractors are a direct cross to John Deere Tractor Models. Any John Deere tractor under 100hp is/was Mfg. by Yanmar for 30-40 yrs or so. Good Luck!!
Jun 10, 2012 | Garden
I need a parts diagram for a cav fuel injection pump. Came off david Brown tractor Model 770 A.
Go to case IH parts on line and find your tractor model and pump diagram
Aug 06, 2011 | Diesel Garden
Deisel fuel getting to injector pump. Feul also getting to pump bleeder. No feul getting to injector lines or return line even as engine is being cranked. Machine is a 530 case construction king. Tractor...
you prabably have an airlock inside the injector lines.
Disconnect two lines and crank again,this will push out the air so fuel can get to the injectors.once the fuel comes out reconnect the lines and it should start
Aug 29, 2017 | Milwaukee Tool Case Heat Gun
The tractor is burning oil fast,I check it every time I us it. It's has started smoking when i engage the blades. I just changed the oil filter, air filter and fuel filter about 4 weeks ago.
Most likely you have a blown head gasket,check the fuel pump to see if oil is coming out of it or the line to it is fill with oil.If this is the case replace the headgasket.
Nov 27, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
AIR IN DIESEL FUEL LINE
It be probably in the tank,check the pipe that goes inside the tank.
Nov 16, 2009 | The Times Case Corporation Tractors...
Fuel gauge inop on a 2000 john deere 5310 tractor
Either the fuel gauge has given up the ghost or the sending unit is not properly grounded, in which case the fuel gauge would not work. Hope this Helps, Don
Oct 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
89 people viewed this question
Top NRS Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a NRS Garden Expert? Answer questions, earn points and help others
