Question about Apple iPhone Smartphone
I phone screen is to large to take password off
    President:
  • 239 Answers
Double tap the screen with 3 fingers and it will unzoom. Or drag screen using 3 fingers to enter password then double tap as above. Then to switch the feature off,
go to settings, accessability and turn off zoom feature.
Hope this helps and if so please vote.
Thanks
Jim
Posted on Feb 07, 2010
Wow thank you so much it worked! I've been stressing all Day with this large screen ..... Hugh! you saved my day Jim.... I love you!!! :~D
Posted on Sep 11, 2011
I WANT TO PUT A PASSWORD IN MY AMSONG PHONE
How to set up the screen lock on my Samsung Galaxy S4
support.bell.ca/.../Smartphones.../Samsung-Galaxy-S4.how_t...
Bell CanadaYou can set a screen lock (password) for your phone. The password will be required to unlock the phone from standby mode.
How to set up the screen lock on my Samsung Galaxy S III
support.bell.ca/.../Smartphones.../Samsung-Galaxy-S3.how_t...
Bell CanadaYou can set a screen lock (password) for your phone. The password will be required to unlock the phone from standby.
Dec 28, 2015 | Cell Phones
Www sonyerricson com
Welcome to the world of large screen, smart phones.
The screen takes a large amount of battery and your apps will be constantly checking in "Online" which means it costs you money in data charges.
Solutions
Turn your screen brightness down
Turn Data off in Settings
May 14, 2013 | Sony Ericsson XPERIA X10 Cell Phone
M8800 touch screen frozen
First you need to take out the battery and insert it back on, then you power it on, it should work, after that, you need to calibrate the screen once it is working properly, if not, it will freeze again.
To calibrate the screen, you need to go to the phones menu>settings>calibrate> Then you touch the center of the star that comes up on the screen, after doing it perfectly, the screen will work perfectly fine once again.
There are 2 causes of the screen freezing. 1 is if you have too many large files on your phone, and 2 if the sensor board of the screen is weak, calibrating the screen will solve the second problem or replacing the sensor board if calibrating the screen does not solve the problem.
For the first problem, what you have to do is to assess the files on your phone, if they are too large, the phone will continue to hang because it will be taking longer time to process the file opening. Try to move the large files to your computer or laptop, if not, it might cause further problems to your phone.
That should solve the problem for you.
Jan 09, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
I forgot my memory card password .. plz help ??? thnx
you can use the Nokia 5310 for many different storage and entertainment functions. The mobile phone has the ability to save all of your large files (such as pictures) to a memory card instead of using up all of the built-in device storage. You may run into issues with the memory card if it is locked. This can happen if you buy a used card or if you forget the password that you programmed into the card at the time of purchase. You can unlock the card with a default password, or you can delete the option that requires the memory card from requiring a password at all.
Instructions
          Unlock the Memory Card
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.
    2. Click the "Menu" key down from the main screen of the 5310. Select the menu option for "Extras."
    3. Navigate the cursor down to the bottom of the page. Press down on the option for "Memory Card."
    4. Click the "Options" selection that appears as a screen prompt. Move through the options until you reach the "Unlock Memory Card" option. Click the cursor to select the "OK" option.
    5. Manually enter in the unlock password with the 5310 keyboard in the password box. When you cannot remember the password, the generic passcode is "12345" or "1357."
          Delete the Memory Card Password
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.Click the "Menu" button down from the main screen of the 5310. Select the menu option for "Fun & Apps."
    2. Scroll down to the selection for "Gallery" and then press on the "OK" key. Navigate to the "Memory Card" screen selection and then press on "Options." Move through the list until you reach "Memory Card."
    3. Press down on the option for "Delete Password" when the screen pop-up menu loads. Verify that the words "Memory card will unlock now, do you wish to proceed?" appears. Select the option for "Yes" to verify the unlocking.
    4. Navigate to the password box and manually type in the default passcode. When you cannot remember the password, the generic passcode is "12345" or "1357." Select the "OK" key when you are complete to remove any passcode requirements from the 5310.
Dec 08, 2010 | Nokia 5310 Cellular Phone
IPhone Smartphone: my screen has gone large on my iphone...
Double tap the screen with 3 fingers and it will unzoom. Then to switch the feature off,
Thanks
Jim
May 18, 2010 | Apple iPhone Smartphone
I phone 3g went from normal screen to large screen how to change it back to normal
Thanks
Jim
Jan 01, 2010 | Apple iPhone 3G
Iphone has zoom on making apps very large. Can
Go to "Settings">"General">"Accessability" and turn "Zoom" off.
Dec 14, 2009 | Apple iPhone 3G
Home screen magnified so large can't enter unlock code
Use three fingers and double tap on the screen. It's part of the new accessibility features on the 3GS.
Jul 04, 2009 | Apple iPhone Smartphone
I850 Large Screen problem
The backlight on the phone has probably burnt out. The only way to fix this problem is to get the flip on the phone replaced. This will work almost 100% of the time.
Jun 07, 2008 | Motorola Mobility i850 Cellular Phone
Apple iPhone Smartphone Logo
44 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
