Question about Emerson LC320EM8 32 in. LCD TV
We have a green line going down middle of tv. We have not even had tv for a year. Line someties goes away.
    Genius:
  • Emerson Master
  • 1,039 Answers
The panel is bad. You should have a 1 year parts and labor warranty on this.
Posted on Oct 04, 2009
60inch lg plasma green line down the middle
Visit this site named 'Electro-help' These type of fault to plasma TVs are described in detail there. Almost all plasma TVs will have same structured circuits. You can find which board to your TV is faulty, by referring details from this site. Check this link, and select the site named above. Pull up older posts there.
Jul 30, 2012 | LG 60PS60 60 in. Plasma HDTV
How do fix a hitachi tv with a 2 inch black line down the middle
try to play dvd movie first on your tv to see if the problem is on TV or the antenna connection
Jul 18, 2012 | Televison & Video
Why does my tv has a line in the middle of it
Is it a vertical line or horizontal line? Does the line go away when you turn the TV off? If the line goes away when you turn the TV off, it is probably due to the "signal". Does the line go away with different inputs? If so, the cause is the specific input signal.
Apr 02, 2012 | Sylvania Televison & Video
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Nov 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Black line on middle of screen
Hopefully you still have under warrantee. If not, sorry. This line if memory serves me right is because the tv has 2 picture panels on each side of the TV (they join up together to make one picture). Toshiba did not realize that the panels will start slipping thus creating this fine line from the top of the screen to the bottom. They have revamped the newer models and placed glass to adhere the panels together. Even though my TV was under warrantee I got a new one and have had this one for 1/2 year and now the picture just blew (there is sound but no picture.)
Take your TV back if it is under warrantee.
Dec 11, 2008 | Hitachi SSH2442 Television
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
TV has line down the middle
Remove the front sceen and check for a cob web acrossone of the px tubes, is one possible cause of your problem.
Jun 15, 2007 | Panasonic PT-47XD64 47" Rear Projection...
Emerson LC320EM8 32 in. LCD TV Logo
473 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
