Question about Acer AL1717 17" LCD Monitor
How to remove the base from the viewsonic vx2235wm monitor. I don't find any clip.
  • 11,361 Answers
You have to remove the two snap-on plastic hinge covers to get to the base mounting screws.
Posted on Jan 10, 2010
Our viewsonic monitor is VX2235WM-3 the
The short answer is no, becuase by time you pay the $50 for the backlight, and $75/hour for the tech to fix it, you can buy another 22inch for the same price and have a 5 year warrinty.
Sorry,
Have a nice day
Aug 29, 2011 | ViewSonic VX2235WM Monitor
How to open a viewsonic vx2235wm monitor?
Here is a link to a repair guide with pictures and videos showing how to open the unit and then repair the power supply board that is the most common cause of issues in the VX2235wm monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2010 | ViewSonic VX2235wm LCD Monitor
Trying to pack
Few steps to take the stand and base off the 22" ViewSonic VX2235WM
1- Squeeze the bottom of the base to take the base off from the collar
2-This step is very important. The collar has two parts snapped in together, with 3 snap in each side. Carefully use small flat screw driver to take off the back side of collar
Feb 19, 2010 | ViewSonic VX2235WM Monitor
Viewsonic monitor -- VX2235wm LCD
avintagedish, Possible problem w/unit power supply. Go trade it in on new a new wide screen so the electronics technician in the repair area of the store can (with a little luck) put less than $10 in parts into your unit and maybe have a nice VX2235WM to give to his 10 year old kid to play games on. I sure hope you have a valid warranty!! You should verify that VX2235WM does same at KNOWN GOOD pc!!! Swap-in a KNOWN GOOD monitor to prove pc is OK!!! Read my FIXYA profile and learn "flashlight test" for "rude an crude" test of "switch-mode-power-supply" status. Follow the links you find there to other web sites for more info. Check to see if ViewSonic has a cash+old swapout for factory refurbished unit for premature failed units! I'm lmistyrel over on aim. and 12fixlouie on FIXYA good luck in your quest to fix unit. It can be fixed. Just do your research FIRST! So you don't get ROOKED if you contract out the work. Read, read, and read some more!! Visit YOUTUBE for video clips of LCD monitor repair and disassembly. FYI.
Bye for now.
Feb 05, 2010 | ViewSonic VX2235WM Monitor
I have a problems with my Viewsonic vx2235wm, the On/Off button does not always make a good connection in turning off the monitor. I will push it and it will go off and then come back on immediately. The...
press it several times very very quickly, if it doesn`t start functioning the front panel must be opened in a service and the contact cleaned...i don`t think it needs replacement
Oct 28, 2009 | ViewSonic VX2235wm LCD Monitor
I need sofware of my viewsonic
The links below are two picture of the CD came together with the viewsonic monitor.
http://i590.photobucket.com/albums/ss341/VHC08/VX2235CameraAssistantSoftware.jpg
http://s590.photobucket.com/albums/ss341/VHC08/?action=view&current=VX2235Driver.jpg
If you happen need the driver only viewsonic.com has it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.viewsonic.com/products/archive/vx2235wm.htm
X2235wm User Guide, English PDF: 513KB
The CD contain Camera Assistant Software is only 18M, which is an executable file. The software is not too impressed to me. The other CD is the driver disc. It also has a pdf owner's manual and the Adobe reader 4.0
View More Drivers/Utilities »
Jun 03, 2009 | ViewSonic VX2235WM Monitor
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
Viewsonic vg2021m base mount
Gently lay the nonitor, face down, on a table such that it will not be damaged while you remove the base. You will find a curved strip of plastic about 1 1/4 inch wide and 4 inches long. Near the center of this strip, you will find two parallel plastic ridges. These are clips that hold the base to the monitor support post. Squeeze these clips together to remove the base from the support post. I was able to squeeze the rear strip toward the rear of the base and ease the rear of the base off that clip and it came apart ok. It is a bit tricky, but doable. Good luck.
Orval
Dec 08, 2008 | ViewSonic VG2021m LCD Monitor
Acer AL1717 17" LCD Monitor Logo
1,859 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
