Question about Miele S251 Flamenco II Bagged Canister Vacuum
Air leak The air leaks out at the bottom of the door (to the filter compartment) right above the controls.  We have to plug that space with tissue to keep up the vaccum/
    President:
  • 1,673 Answers
Check the seal that is in place between the top and bottom sections. If it came out of place even a little, it will leak and you lose suction. Part number 03611180, it is called a buffer.
Posted on Jan 15, 2008
Keeps Turning Off
A possible answer is right at the letter head above, look to see if the air filter is dirty or blocked up.
Dec 14, 2012 | Envirocare Tristar Compact Exhaust After...
I have a dyson, and i'm not getting any air thur the hose, the hose is not blocked, when u take the dirt container off you see two holes one round in which air is very strong the other which is kinda...
have you tried to clean up a toner spill from a laser printer? If so, this will instantly block the lifetime hepa filter that is under the normal cleanable filter above the motor. Otherwise look for missing seals, or cloggs. The cyclone chamber should be cleaned out every 1/2 year as well.
Good luck...if all else fails, call Dyson...they have some very good support people.
Sep 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
How do you change the filter on the sebo X1.1 mine seems to be stuck
Assuming you mean the long cylindrical filter that's in the bag compartment, you just pull it out using the little handle at the bottom. They are sometimes very tight, and you can use something like a screwdriver to lever it out (care not to damage the main casing). When inserting the new filter, lift the little metal lever so it's pushed up behind it (that's just a device that stops you closing the door with no filter in place.
I hope this is helpful. If so, please remember to rate my response. Good luck!
Feb 05, 2010 | Sebo Air belt K3 Bagged Canister Vacuum
I was given an Electrolux vacuum model 1401-B. I would like to download a manual for it. Do you have one? Thanks, Carolyn
Carolyn, The 1401B is one of a family of US built LUX models , now sold by AERUS Electrolux. It shares common info with the MARQUISE, Super J , Olympia and 1205, etc so if you come across a used manual for any of them you will be in good shape.
Try an AERUS Electrolux dealer but the manual may be out of print.Also try a local vac shop
Quick rundown, :
Set the dial at front between medium and fine and don`t adjust, this is the bag fill control, NOT a suction control.
Only use genuine 4 ply filter bags from a pro vac shop, not grocery store grade as this is a vac which filters thru its bag.
Hang the hose for longer life, obstructions can be blown out thru plugging the hose in the blower port under the slide door behind the handle.
Inspect the power head for hair and thread and remove any visible.
When you wheels squeak while vacuming spray the axle shaft behind the neck with a drop of WD 40.
If you feel air venting thru the hose behind the handle or if it is crushed and kinked there or at the vac replace the hose for better suction. The weight of this vac weras out hoses. When the castor below the body cracks and it will, match it with a small SHEPARD castre at the hardware store.
If your rewind is sluggish, pour a tablespoon of talc or baby powder in a tissue and run it up and down the lenght of the vac cord end to end. Then drop the tissue into the vac bag fro fresh scent.....
Enjoy the vac, this one is a great one 30 year plus life span, parts are still available keep it in good repair
Oct 10, 2009 | Vacuums
My canister machine kicks off immediately after starting and bag full light goes on but it has a new bag
hi from uk your problem with vac may be the gauze filter on the inside of the compartment that has bag this filter there to allow air from the micro pores of the bag to expel to the exterior of vac (room) whilst preventing dust from expelling too ? normally another symptom of this is the vac cover sometimes flips up ? however if air cannot expel from compartment it will cause overheat of motor resulting in auto cut off but will reset when cooled SO check the filter gauze and renew or wash clean? hope you understand above and hope this helps ?
Oct 09, 2009 | Electrolux Guardian Bagged Canister Vacuum
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
Apr 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
I need to know how to remove the dirt container on the eureka bagless vacuum. It says that it is easy to remove, yet we cant figure it out. is there some trick to it that we dont know?
there is a lever at the bottom of the dirt cup,turn it to the left and pull out the dirt cup.note while you have the dirt cup out make sure you clean all the filters there is one right above the dirt cup pull out on the right side and there is a filter on it and at the bottom right below the dirt cup there is a door that says hepa.clean that one to.then your good to go
Apr 23, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Install filaters
not sure which filters you have ... i will assume you have a replacement cassette micron filter -- goes in the compartment on the front of the vacuum just lift up the handle on the compartment and swing upwards it will pull out like one large piece the filter is on the back. the cassette door will be hinged at the bottom so just pull firmly from the top and snap back in place after replacing the filter. Replacement HEPA filter cartridge --- attaches to rear of Eureka upright vacuum cleaners. Here is a pictorial or changing the filters : http://www.eureka.com/servlet/FindOwnersGuide
Mar 08, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Miele S251 Flamenco II Bagged Canister Vacuum Logo
163 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
john h
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
