Question about HP DesignJet Z2100 InkJet Photo Printer
Doesnt Print I Have Problems Resetting my Printer To erese a problem
    President:
  • HP Master
  • 2,923 Answers
If you are having a problem resetting the printer to erase the problem, then contact the manufacturer and request for a firmware upgrade. For sure, the printer would be reset. Aside from that, you're printer will work accurately and better.
Have a great day!
Posted on Oct 04, 2009
Zebra TLP 3842 isn't printing
Step 1:Firstly, restart the computer and check the print queue.
After the computer restarts, double-click the printer icon in the lower right corner (the notification area) of the computer. The print queue opens.
If theprint jobs remain in the print queue,continue to the next step
Step 2: Run theFixitavailable in the link below:
Troubleshoot-printer-problems
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
Step 3: Make sure the printer is not paused or offline.
1. On the print queue menu bar, clickPrinter, and then look for thePause PrintingandUse Printer Offlineitems in the menu.
2. Make sure that there is no check mark next to either item. If a check mark displays next to either item, click to clear it.
Change-your-default-printer
http://windows.microsoft.com/en-us/windows-vista/Change-your-default-printer
Step 4:Run the fixit available in the link below to restart the Print Spooler service.
Fix printing problems by resetting the print spooler
http://support.microsoft.com/kb/2000007
You may try to add the printer locally and test
Add-or-remove-a-printer
http://windows.microsoft.com/en-us/windows-vista/Add-or-remove-a-printer
Mar 06, 2014 | Zebra TLP 3842 Thermal Label Printer
Canon 5750 Won't print the color, although it's set to do that, and cartridges all have ink in it. I deep cleaned and also ran a nozzle check ... but don't know how to interpret that. A = 0 B = -1 C =...
Hi Sue, first tell the exact printer model, because MF5750 is laser printer B&W, lbp5700 is also laser and doesnt have ink.
Wich ink printer do you have like pixma 5300? pixma 4300?
The 5750 doesnt exist in canon range of printers.
But, by your description you have print head problems or clodged inks or purge unit problems.
Aug 28, 2010 | Canon LaserBase MF5750 All-In-One Printer
Hp 5180 ink shows empty and won't print but new cartridges were inctalled.
I don't know whether you received any notations besides low ink levels. I found that when my printer wouldn't print, someone suggested resetting it. I don't remember just how I did this, but you might look into this. I thought I would need to buy a new printer because it said I had a fatal error. Apparantly, if the ink levels are left low for too long, the printer has problems.
Jun 22, 2010 | HP Photosmart C5180 All-In-One InkJet...
Doesn't print black, even changed new cartridge
How long was the printer sitting not used? That ink is pigment based and is nasty when it dries out. The colors are dye based and do not have similar problems. It is likely the pigment has dried in your print head and clogged it. If print head cleanings are not fixing the problem, and you a confident in you abilities, you can disassemble the machine and pull the print head out. With it out you should let it rest for about 15-20 minutes on a paper towel soaked with warm (100 F) distilled water. CAUTION, ink will seep out of the print head, be sure to due this on something ink resistant, shop bench or plastic plate.
Dec 19, 2009 | Canon i860 InkJet Photo Printer
My printer is not printing any document and when i check whats printing it says its deleting another document
click on start
goto control panel
select printer and faxes
double click on printer icon
and delete all the que printing jobs
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Printer will not print
Below are instructions for resetting the printer. However, if they don't work, you may have to have the unit serviced - if it's still under Canon's 1 yr warranty, go through them... if it's not, I would weigh the cost of repair to what it would cost to replace the unit altogether.
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, power down your computer as well -- and unplug the USB cable (from the printer) from your computer,.and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer and computer back on.
Good Luck!
Maggie B
Feb 24, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
PRINTER REBELLION!!
If the printer is more than a year or two old, it might well be the service or counter codes need resetting. Try running the SSC program (search on the web) and resetting all of the counters.
Nov 13, 2007 | Epson Stylus C42UX InkJet Printer
HP DesignJet Z2100 InkJet Photo Printer Logo
163 people viewed this question
Seeker5211
Seeker5211
