Question about Pioneer VSX-D509S Receiver
Just fried my 2nd home stereo receiver
Fried the last one a couple weeks ago. Assumed it was due to poor ventilation (it had something sitting on top of the vent) went out and got a pioneer the same day. It has played fine all the way up till today...it's completely fried and won't even turn on.
The first one (sony) we've had for about 5 years. The only change that has been made is we added an optimus 12'' subwoofewer that I picked up from a yard sale. Could it be frying the receivers???
    Problem Solver:
  • 5 Answers
If the Optimus subwoofer is passive (no internal amplifier, powered by the Sony or Pioneer) it is possible that the subwoofer's driver (cone) has a shorting voice coil. This will blow the amplifier section of your receiver(s). Check the receiver's fuse(s). If you are lucky, the fuses blew and the receiver circuitry is OK, if not, it will require professional service. In any case all the rest of your audio system should be checked before reconnecting the receiver.
Posted on Oct 04, 2009
  • 84 Answers
Yeah check the ohms for the receiver an see what the subwoofer ohms are.that can fry them
Do all Kenwood Home stereos have fuses?
yes there are fuses. usually they are glass fuses near the power input on the board inside the unit. but you could also have fried or corrosion damaged other electronics if you have dropped water inside it
Nov 24, 2013 | Car Audio & Video
I spilled a liquid in my jvc rx-502ov receiver and a message reads dsp micom ng what do i do?
You fried the poor thing to put it mildly, Get a different one end cut down on your partying ,(GUY) Unless you have money to burn
Dec 05, 2012 | JVC Rx 5020v Stereo Receiver
My home stereo Sony when turn on the word 'protect' comes on and doesn't moves from there
"protect" usually means speaker wires are crossed or speaker ohm load is too low. if you have more than one speaker connected. if you did not change anything since the last time you used the radio the internal amp might have fried and you should have the radio serviced if the cost is worth it.
Dec 23, 2010 | Sony Audio Players & Recorders
Motor does not fire but did this morning before i took it out
well most likely you fried the control module .hooking battery up backward even for a couple seconds will do it .
Mar 08, 2010 | Boating
Stereo won't turn on
It could be fried, but some of these stereo's have fuses on the back of the radio. Example: I have a fuse under the dash and 2 on the radio. Take the radio out and check the fuses, then check your radio harness for power. If you have power coming through your harness, then most likely the radio is fried.
Feb 24, 2010 | 2001 Audi A6
My powerbrick lightis orange but my xbox360 wont turn on
If the light on the power brick stays orange after turning the console on it means the brick is not properly functioning. You can attempt to clean the power brick with a can of air. Also make sure it has ventilation and is not sitting on carpet. This can cause the power brick itself to overheat and cause issues with it and the console itself. Also make sure your 360 is not plugger into a surge suppressor as this can cause issue due to double protection.
If possible, test the power brick on a different console, and test the console on a different power brick. This will narrow down your problem area.
Dec 22, 2009 | Microsoft Xbox 360 Pro System Console
Yamaha RX-V750 wont power up
Check the fuse. You might have had a power surge which blew a fuse. If not, check the fuse for the socket. Reset the fuses for that socket. If it still doesn't work, it sounds like the internal boards got fried, or the power supply got fried. The power supply is replaceable, but we don't know if it is the power supply. To check, connect a voltage meter to the power supply.
Something like this happened to me. I found a new kenwood stereo next to the dumpsters, stickers and all still on it, plugged it in, it worked, shut it off to plug in a speaker, didn't turn back on, months later after leaving it plugged in, turned on, I used it, then shut it off for the night, in the morning the standby light was still on, tried turning it on, but it wouldn't for some reason, unplugged it, then the light wouldn't come on, it was once again sitting on a shelf as a paperweight, one day it randomly came on again, and now it 100% works, and I use it as an amp for my RE audio subwoofer, and its worked great since! The reason this kinda applies to you is because its kinda simmilar what happened to you. Just leave it plugged in, and maybe sometime you will walk by it noticing it works.
Oct 10, 2009 | Yamaha RX-V750 Receiver
Car overheating
Good chance. The temp sensor in the radiator could not be reading correctly. Or the fan control module is on its way out.
May 26, 2009 | 1995 Volkswagen Golf
My panasonic sa-ak58 home stereo, it turns on o.k. but after a couple of seconds i loose audio, on all speakers, but the led screen shows normal volume level, no matter if is high or low on volume.
go on the back of the stereo take a aux cable and hook to the back and touch the end were it plugs in to the mp3 r what ever you use and if its still making the nosie your amps fried
Aug 28, 2008 | Panasonic Audio Players & Recorders
Front buttons won't work
The microprocessor may be locked up. While pressing and holding "video 1", press "speaker A". When "clear" appears in the display, the micro has been reset to the factory default condition. To do a full reset without taking it apart, it may have to sit up to 3 weeks for the backup battery to run down.
Dec 21, 2007 | Onkyo TX-DS474 Receiver
Pioneer VSX-D509S Receiver Logo
233 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
