Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
Stuck in gear forward will not shift into any other gear
80 pound stern mount 24 volt Riptide. When I hook it to the batteries it starts moving forward even though it is in the off position and does nothing when I throw into other gears. It just keeps going the same forward speed. Thank you
    Problem Solver:
  • 6 Answers
Possiblty a shorted power transister in the speed controller.
Posted on Nov 24, 2009
The turn feature on my remote trolling motor will not work
Maybe the pin is sheated on the prop...or something is caught in it..
check the prop.
Dec 30, 2012 | Minn Kota Riptide St Saltwater 80 Bow...
I have a riptide st 80 24 volt bow mount co-pilot. Still under warranty but has worked well for 9 months. When I start unit, it works well for 15 seconds (more/less) and then shuts off with the green on...
Start to look for the charge state of your battery.
Measure the voltage on the battery connectors when the motor falls out. If lower than 11v your battery is too weak.
Also check all the cables between battery and motor. Check foor loose connection or oxidation.
Aug 19, 2017 | Minn Kota Riptide St Saltwater 80 Bow...
Riptide RT65 24 volt with auto pilot goes nuts.
your magneto is shorting [ arcing on high needs, openup and replace magneto. call minkota and order a new magneto for your model, unless under warrantee.
Apr 13, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
Nov 18, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
I just bought a 74 lb Minn Kota trolling motor that is 24 volt. It is used and has 4 wires (2 black & 2 red) coming from rolling motor. Can you please tell me how the wiring is connected to the...
I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
Oct 29, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
1986 170 horse mercruiser lower unit,water pump destroyed .100 inch play between timken bearing and race, driver shaft wobbles. to dissasemble lower unit in which order do you remove shafts, shifter shaft,...
Gear cases are easy to take apart with the proper tools.I suggest buying a Clymer Manuel. it has a list of special tools. TEAR DOWN PROCEDURE(1) remove the propeller shaft bearing carrier assembly by removing the carrier ring. takes a special tool. (2)the bearing carrier depending on the running condition will become stuck in the gear case. there is a special tool for removing the bearing carrier out of the gear case.(3) the bearing carrier houses the reverse gear make sure the reverse gear was removed when the bearing carrier came out. (4)look inside of gear case you will see the propshaft assembly, drive shaft with pinion gear assembly, and the forward gear.(5) on the drive shaft pinion gear you will see a nut. there is a close clearance between that nut and the clutch dog on the propshaft assembly. it takes a special wrench to get this nut off plus a spline tool to hold the drive shaft as your turning the nut off. you can make them both but be careful.(6) there are two different styles for this model of stern drive a "R" and a "MR" the "MR" drive has a retaining nut for bearing preload for the drive shaft. need special tool to remove it. the "R" drive has a spring loaded pin on the top of the driveshaft to control bearing preload. no special tool need to remove shaft after pinion nut removal.(7) once the driveshaft is removed the propshaft comes out by lining up the shift shaft just right. (8) turn the shift shaft until the shift crank is at a right angle to the propeller shaft. you can't see the shift crank because it is behind the forward gear you have to go by experience or feel. once you have the shift crank lined up properly push the propshaft to the left side of the gear case housing then pull out at that angle. GOAL propshaft "clutch dog actuating shaft" in basic terms, is like a hook that grabs onto the shift crank. you unhook it by moving the propshaft tip to the side, causing the back of the propshaft inside the housing, to unhook and move away the the shift crank. it sounds complicated but once you do it you see how easy it is.(9) once you have the propshaft and the forward gear out you can leave the shift shaft inside.there is no need to remove it. have fun
Sep 06, 2009 | Boating
Bad control board
If the voltage on your boat's plug drops down to .8v, then the problem is almost certainly in the boat. Trace the wires. You probably have a corroded wire connection somewhere. If there is a fuse in the circuit, check it and it's holder very closely.
Jun 13, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
200 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
