Question about Garden
While cutting up downed trees the saw chain locked up. I took the cover off and cleaned the saw dust etc. Cranked and almost immediately the chain stopped again. Saw smoke coming from clutch area, but saw was not overused and the oiler was working fine.
  • 2 more comments
  • dojdea Oct 04, 2009
    I checked the chain brake thnking that was the problem but it's not. I'm thinking it may be the chain bar. I will check tomorrow.
  • dontbother10
    dontbother10 May 11, 2010
    Echo boasts a five year warranty. If you didn't trip that brake it is dragging, causing things to get hot. If you did trip it it is supposed to stop the chain, it didn't. I recommend you discuss this with Echo. IMO your saw needs attention. Lou
  • dontbother10
    You can respond below the adverts.
  • dontbother10
    I have to ask. Did you unlock the chain brake? Grasp the forward most top handle and pull it aft. Does it click? I think you tripping the chain brake accidentally or are cutting with it engaged. Parts lists for your saw can be found here: EchoUSAhttp://www.echo-usa.com/faqs.asp HTH Lou
    President:
  • 2,220 Answers
Unless the bar is dragging on the clutch I don't see how it can cause the clutch to smoke. Please let me know what Echo says.
TIA Lou
Posted on Oct 04, 2009
  • dontbother10
    dontbother10 Oct 04, 2009
    http://www.echo-usa.com/pdf/documentatio...
    Page 14 item 2, (bearing) If that failed that might cause this. Where did I get the idea its an Echo? Is this a Homelite? A couple of others have had a similar problem with a Homelite. Please provide the make and model, else I won't get any sleep tonight.
  • dontbother10
    dontbother10 Oct 05, 2009
    Sleepless in Seattle.
    Lou
Will not stay running
Clean carburetor-verify fuel line blockage-clean filters-make sure your gas/oil mix is correct-use fresh gas. They shut down frequently when setting them down-Increase RPM at Idle.
Jul 27, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
McCulloch ES335 electric chainsaw whilst cutting a fallen tree into pieces The saw made a load click like sound when restarted and them the engine run but no movement on the chain. I took off the cover and...
In front of the handle on top of the saw is a hand guard. If in the course of cutting wood you hit it or pushed it forward, it will lock up the chain drive system. It should pull back towards the handle until it again clicks to release the chain. It's designed to lock up the chain drive and stop the chain when the saw kicks back.
Feb 10, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Yesterday around five i was chopping some logs out of a small tree i felled. i was doing a under cut to the top tru a small bout three inch tree. next thing i know my blade isnt spinning. so i stoped for...
I don't have any poulan saws mine are all stihl and homelite but they all have a chain lock on them .It is located on the front of the motor on top of the saw and if they are hit fairly hard they will lock down on the chain to prevent injury. Try to push the bar forward then pull it back towards the rear of the saw. You should hear it click when it resets.Hope this helps you. Thank you
Jan 06, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Hi. Used my chain saw for the fifth time since purchased new. Each time of use I drained gas etc, and had no problems. A tree fell in my back yard and I got to cut 3 branches and my chain saw stopped...
Did you buy this saw new and do you have owners manual. If you feel that this is a design flaw I would call Poulan directly, and politely inform them of your problems and see if this is a common problem. I would also reccomend that you inform them of your loyal use of their products and see if you can get them to do anything to help you. A lot of people think that these big companies don't care but it has been my experience that if you are polite and calm most of them will try to help. Remember you will catch more flies with honey then you will with vinager. Poulans phone number and e-mail no. should be in your manual.Good luck. Thanks
Nov 19, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Need to know how to change chain on a 14inch McCulloch Eager ****** gas chain saw
Turn the chain adjusting screw CCW a turn or two, release the chain brake, and remove the large nut on the right side cover. The bar and chain will come off after removing the cover. (note: a 16" bar and chain will fit the saw which makes it a little more useful if cutting trees) Be sure to clean the small oil passages in the drive end of the bar that run from the large holes out to the chain groove on each edge. It is common to flip the bar over to equalize chain groove wear. Also, if the outer corners of the bar edges have wear that causes the metal to flare outward, use a file to cut off those sharp edges (at about 45 degrees) so that it doesn't project beyond the bar's flat surfaces. This will help prevent a cut from wandering off to one side. Re-assemble in reverse order after cleaning the engine and cover. You may have to turn the chain adjust screw some more to compensate for the old chain which will stretch with use. Make sure the adjustment 'tang' falls into one of the large holes in the bar before tightening the cover nut down. Hope this helps!
Nov 10, 2010 | McCulloch Garden
Chain won't rotate
Assuming that you have a fueled engine saw instead of an electric type, remove the drive cover after releasing the chain brake and backing off CCW the chain adjuster screw. Remove the bar/chain and clean the assortment of parts including the small oil passages that are in the drive end of the bar. Wash out the interior of the clutch assembly with spray carburetor cleaner and let dry. Start the engine without the bar/chain and watch for oil oozing out of a small port in the side of the engine case. If nothing, check the oil pump, lines, and valve/filter within the oil tank. If ok, re-assemble the bar, then the chain over the sprocket and out over the bar. Extend the bar out to tighten the chain, and fit the cover to the saw. Tighten the fasteners finger tight, then adjust the chain up to the lower bar edge (the teeth cut toward you on the bottom run) but not so tight that you can't turn the chain by hand. Tighten the fasteners and recheck chain tension. Check chain oiling by running the bar tip at speed near a piece of cardboard for a few moments--it should throw off a thin line of oil onto the board. Hope this helps!
Jun 26, 2010 | Garden
Husqvarna 350 oil not getting to chain
Take the bar and chain from the saw. Clean the two small ports that run from the large oil holes at the drive end of the bar out to the chain groove on each side. Clean the entire chain groove. Start the engine with these parts removed--oil should ooze out from the side port in the engine case with the engine running at med speed. If it doesn't, then there is trouble near the pump inside the case. When everything is back together, run the saw at full speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard after a few moments of running. Hope this helps!
May 26, 2010 | Husqvarna Chain Saw 20" Bar
When i try to do a horizontal cut my saw seems to bite in for a start, but then just runs free in the tree not taking a bite or drawing the saw in, this has also happened with 45% cuts, is this my own...
Sawing with a chainsaw is mostly 2 part, a sharp chain and good technique.
If your bar is straight, your chain is razor sharp and the oil reservoir full then it boils down to technique.
You cannot run a chainsaw through horizontally on a big tree, what will happen is half the time the tree's weight will begin to collapse upon the bar and pinch it in the tree and you will not be able to saw any further.
You will notice that when felling a tree the vertical cuts are always problem free because gravity pulls the off-cut away from the saw. With horizontal cuts fire your blade in at an angle, and in cut in the direction the tree (or whatever) is likly to fall. As you cut rock your blade to help it bite into the wood and resist jamming. If your chain jams do not keep on the gas for you will burn out the clutch.
For an awkard cut instead of feeding it right through cut towards the middle to create a notch, then cut from the other side, the weight of the tree will fall on the cut portion leaving your blade free to slice through.
Just think logically and make sure that the blade can feed through without getting pinched, this is well represented if you get a log and support both sides then cut vertically in the centre; it will get pinched imeediatly. Now cut from the underside and it will fly right through.
This is difficult to describe but plan your cuts and test it out.
Cheers,
Kevin
Feb 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
226 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
