Question about Saeco Magic De Luxe Espresso Machine
Mold inside reservoir tube
We haven't used the machine in a few weeks and just discovered there is something that looks like mold inside the tube that takes water from the reservoir to the coffee spout. Have had the machine a while and never had this problem before. Tried just flushing water through several times but didn't help. Thanks!
    Top Expert:
  • Saeco Master
  • 12,104 Answers
Use vinegar run about 1 1/2 cups thru machine if not clean completely try getting a pipe cleaner thru tube
Posted on Oct 04, 2009
Tip
Sound like your power steering pump is going bad? Not necessarily...
I had a customer that told me their power steering pump was going out. They described the typical power steering whine and difficulty steering. When I went to verify the complaint, I discovered that it didn't whine or have trouble right away. It took a minute or two to actually appear. I had to do some research and what I discovered was that, while a typical vehicle would have the return hose connect directly to the bottom of the reservoir, in the volvo it connects near the top. Inside the reservoir, to keep the fluid from becoming aerated, there is a small, plastic, "L" shaped tube that connects to the p/s return on the INSIDE of the reservoir. In the case of the vehicle I was working on, this tube had popped off causing the fluid to become severely aerated. The air would enter the system (after developing from running for a short bit) causing it to sound like it had a bad pump.
So, if you suspect that the power steering pump is bad, check the fluid level first (as you always should) and examine the condition of it right after running it. The cap might be pressurized and pop off, which is a very good indication of the problem I'm speaking of. The fluid may pour out as well. In any case, if it's foamy, though otherwise at least filled to the minimum line, look inside the reservoir towards the engine side of it where the return line enters to see if you see either a black plastic tube running to the bottom or a beveled, metal tube that has nothing connected. If you check and see the latter, fish around in the reservoir for the plastic tube. You should find it and can likely pop it back on to the return tube. Bleed the system as you normally would and you should find that the problem goes away. Hope that helps!
on Nov 07, 2013 | 2000 Volvo V70
How safe are keureg coffee makers as far as mold building in the resovier.
Make a cup of coffee then immediately remove the k-cup, notice how the cup is dry? Coffee doesn't enter the reservoir, it leaves the cup through a separate tube at the bottom. No moisture means no mold buildup, but if you leave a used k-cup in the coffee maker for a week or two you're on your own! :D
Sep 29, 2014 | Keurig Coffee Makers & Espresso Machines
Mold in the machine. how do I clean and disinfect it?
The best way to get rid of the mold is to use bleach water. You need to clean and scrub it out, making sure the bleach gets in every cranny. Lastly, really (and I mean really) rinse it out. I would suggest washing it out several times to be careful.
Elisa Jed ' http://www.colfaxcorp.net/services.html
Apr 06, 2014 | Venta Airwasher VS 207 3.7 Gallon...
I have had my hamilton beach brew station for a year. The past 2 weeks, the water put in the bottom reservoir does not empty completely into the coffee reservoir. It leaves about 8 oz in the bottom water...
On your machine there is maybe inside water reservoir a hose or tube that goes down to bottom, or suppose to go down to bottom, to **** up all water. Look inside and see if hose is going all the way to bottom, maybe it got hung up or crooked. Please let me know, glad to help, thanks mike ( mr bean man )
Jun 08, 2011 | Hamilton Beach BrewStation 47214 Coffee...
The coffee side has started leaking profusely from the top, back of the water area when brewing.
There is a red hose that connects at the back and top of the unit. Make sure the hose has not come undone and also check that the top lid with the holes is not blocked with coffee grounds. However, the most probable problems will be the hose otherwise you will mostly have steam coming out the back.
Hope this helps!
Dec 07, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water not pumping through, though steamer works and it makes noise.
You need to get the pump "primed" with water going through it.
If the machine is new or has not been used in a long time, the plastic feed tube(s) in the reservoir will be dry. You have to get the water to slowly creep up these tubes until it hits the pump inside, then the water/steam will come out the head and will keep coming out each time you use it until it dries out again.
I've had to re-prime my Via Veneto several times, and each time it seems like I'm doing it wrong and the machine is broken. But follow these steps and you'll get there.
1. Fill the reservoir with water and put the two tubes in it.
2. Turn on the boiler button (left-most of the two narrow ones)
3. Don't put the portafilter on, just leave the head bare.
4. Turn on the pump and let it run. Watch the water level in the plastic tubes. Understand that at this point, the pump is just pumping air, which it is not designed to do efficiently. As it pumps the air it slowly draws water up the tubes. Really slowly.
5. You can speed this up by putting a cup under the steam tube and opening the steam valve. This is while the brewing pump is still on. You will have hot water squirting out of the steam tube. You may see the water moving more quickly up the tubes.
6. The pump may have to run for several minutes. You'll get impatient and scared something is wrong, but just let it run. You'll see the water creep up the tube and go into the unit. Soon afterward pressurized water will start spraying out of the head.
Now, keep it primed for months by keeping water in the reservoir. If you use it only infrequently, run the pump and at least get some water moving every week or so.
I've tried silly things like holding the tubes upside down, trying to get water forced up into them, but in the end, just let the pump do the work and be patient.
Jul 16, 2009 | Saeco VIA Venezia
The water that comes out of my refrigerator tastes musty.
That is the resivor and that black is mold. Time to replace it, although you could try cleaning it.
May 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Mold
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
Aug 04, 2008 | Rowenta Perfect Iron
Saeco Magic De Luxe Espresso Machine Logo
215 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
