Question about Acer Aspire 5100 Notebook
I have a acer aspire 5100 and my cd drive just quit working, and i have tried external cd drives too, and they won't work either. can any one help me!!
Delete your driver for said cd rom. Then go online and find the updated driver and re-install. Usually solves things like missing cd roms and cameras, etc.
Posted on Oct 04, 2009
I want to replace the dvd drive for acer aspire 5100-3357 with another internal dvd drive but I do't know the type or the model #, all I know is that is a super multi double layer and supports DVD +-...
A better not complicated solution is an external drive.
Like the:
LG GP08LU10 Optical MediaSlim External Super-Multi DVD Drive You might not know it from looking at this DVD drive's sleek, slim exterior, but it's loaded with capabilities. LG's external CD- and DVD-burner looks great, and works in four unique formats. Super-multi read-and-write lets you select your style for maximum performance, while the USB connection means there's no need for an AC adapter.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | Acer Aspire 5100-3357 Notebook
I have an acer aspire 5100 I want to use a USB 1 terabyte
Assuming it's xp or newer,it should just work. Now if this is an older version of windows,like '98,there's a limit on how big a drive can be. You may need to format & partition the drive using 3rd party software that should've comw with the drive.
Mar 08, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 8X DVD±RW DL Burner Drive UJ-850 dvd burn only small files, don't burn movies completly. Itried with several programs like nero , image burn,gburn, etc....sometimes works well, the...
Instead of trying to remove the internal drive, which is still useful, do what I did and buy an external DVD drive, just plug it in with a USB cable...then you still have your internal for nornal stuff and you can move the external around anywhere to take care of the heavy duty stuff...good luck..pls rate this solution.
Apr 23, 2009 | Acer Computers & Internet
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
CD/DVD drive and external harddrives via USB not acessable
I once had a problem like this. It turn out that i just forgot to plug of my external drive. because of the lack of power of the device, it wasnt functioning properly. Try to see if you have two USB plugs, or one Usb plugs with a power cable.  Re check if both of the plugs are indeed connected properly.
Feb 01, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 no longer "sees" its cd/dvd drive- anywhere.
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 21, 2008 | Acer Aspire 5100 Notebook
ACER ASPIRE 3690-2940
check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Sep 30, 2008 | Acer Aspire 5100 Notebook
Acer 5100
please to go to your bios setting and check under boot sequence whether your hard drive is the 1st device. try to reset the bios to its default settings and after resetting it try to check again on the boot sequence to make sure that your hard drive is the first option. if you have external devices connected to the computer remove all of it.
Jun 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer Aspire 5100 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
