Question about Cameras
My LCD screen is black and the pictures I now try to take come out black. The slash over the battery indicator is blinking. I have charged the battery fully and that didn't help. I cannot take a picture even with the ac adaptor. Everything comes out black.
Tip
When your screens blink.. What to do!
A lot of people have had the dreadful blinking of the screens. Whether it's only 1 screen blinking (upper or lower) , or both screens blinking..
I have a tip to help you diagnose the problem so you don't have to waste time trying to find out what's wrong with it, or waste money.
1.) IF YOUR UPPER LCD BLINKS
  • There is something wrong with your lower LCD and/or the connector on the board where the lower lcd connects to.
POTENTIAL SOLUTION
  • Open up your Nintendo DS lite system and clean the board with rubbing alcohol. Be sure to dry the board from excess liquid before re-assembling it. Use a FIRM brush. An regular toothbrush would not work as the bristles are not firm enough.
2.) IF YOUR LOWER LCD BLINKS
  • There is something wrong with your upper LCD and/or the connector on the board where the upper lcd connects to.
  • Follow the Potential Solution to #1
3.) IF BOTH SCREENS BLINK
  • 99.9% of the time, if both screens blink, your light is red. Which indicates your battery is low. Change the battery. If your system isn't charing your batteries correctly and/or you're losing battery power unusually quick, replace the charger.
  • If that does not work, send your system in for repair, as the charging port needs to be cleaned.
on Dec 31, 2009 | Nintendo DS Lite Console
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Just bought a new philips gogear mp4, how long does it take to charge initially and would the screen be blinking when charge to cpu, because mine does not blink.
there is battery indicator in every chargable instrument. try to find that indicator in your media player. initially it should not take more then 24 hrs to charge the battery fully. if the battery indicator does not blink it seems that battery is fully charged. remove charging & observe how long it works.
Sep 13, 2011 | Philips GoGear ViBE Digital Media Player
ZR80 Mini DV Digital Camcorder: I have a blinking red icon with a slash through it...
Sounds like the memory battery indicator. Does it look like a button battery with a slash? If it is, you probably cannot set the date and time also. It takes a CR 1616 button battery and goes in the window behind the main battery.
May 16, 2010 | Canon ZR80 Mini DV Digital Camcorder
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Remote not charging?
the battery can be charged whenever you want to charge it. There may be an issue with the cradle. can you please follow steps below and reply back with the answers?
1) Ensure the cradle is plugged into an active AC outlet and the LED light on the cradle is on. There is a switch on the bottom of the cradle to control the brightness of the LED, set it to the highest. Try different outlets if needed. Does the LED light turn on and stay on (does not blink)?
ANSWER:
2) Remove the battery. Place the remote on the cradle and check the LCD screen. The LCD screen should display a 'White' screen with possible colors before going off. Try this a few times to confirm behavior. Did the LCD turn on briefly?
ANSWER:
3) Reinsert the Battery. Have you charged the battery for at least 3 hours? If no, please recharge the batteries for at least 3 hours.
4) Did the battery ever boot the remote? If yes, please continue troubleshooting.
ANSWER:
5) Remove the battery. Check the 3 gold contacts on the battery to see if there are markings on all the contacts signifying it was connected correctly to the remote. Did the battery have markings on all 3 contacts?
ANSWER:
Jan 14, 2010 | Logitech Harmony One LCD Touchscreen...
Everytime i turn on my Cannon Camcorder GL2 theres a red blinking cursive with a slash and a plus like object thats on top of the slash. what does that mean?
Backup battery needs to be replaced. It's fitted behind a small square panel under the fold out LCD screen. The battery type is CR2025.
Aug 28, 2009 | Canon GL2 Mini DV Digital Camcorder
Camera turns on and focuses, but cannot see menu or take pictures
two things here, have you checked to see if the location to store the pics if it is placed to the intenal memory and the memory is full
also pls try to take a pic with another SD card may be that this card is either corrupted or damaged
Jul 23, 2009 | Nikon D50 Digital Camera
LCD Screen help
How do you get the camera back to the original settings
May 18, 2008 | Fuji FinePix V10 Digital Camera
Cameras Logo
64 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
