Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I need a diagram to remove a drive belt - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
  • 881 Answers
You dont need any diagrams to change a belt just turn the mower up on 1 side and see where the belt goes and if you want to draw your own diagram and keep it safe But then you will find a idler drive pully on all mowers and that is either spring loaded or a nut and bolt holds it tight,,, and that could be the one that drives when you put the lever in CUT but have a good look and its easy to do..
Let me know how you go Ron
Posted on Oct 04, 2009
2003 kia sedona drive belt tensioner diagram
Sounds like you removed the belt prior to drawing a diagram or taking a picture of how the belt runs. Can you add more detail information of your vehicle like does it have power steering, A/C, and if water pump runs off same belt ?
Jun 24, 2017 | Kia Cars & Trucks
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Remove the serpentine drive belt.
Loosen the Tensioner and make sure you memorize the Routing of the Belt.You did not give a year make model but many are on-line if you look. Put your Year/Make/Model and then serpendine Belt Diagram
ie..
99 Taurus Serpentine Belt Diagram and then search.
Apr 16, 2013 | Cars & Trucks
Need to figure out which pulley i need to replace it froze up.
That is sort of easy isn't it
Remove the drive belt & turn the pulleys by hand
The only diagram you need is the one your going to
draw before you remove the belt
The diagram may be under the hood look for it
Jan 21, 2013 | 1993 Ford F150 SuperCab
Passat 1998,4cylinders, turbo, what is the belt routing diagram, the power steeling belt is related with the water pump or not, thank you
The ancillary belts routing diagram for a 1998 VW Passat 1.8 Turbo
AC = Air Conditioning
CS = Crankshaft
F = Fan pulley
G = Generator
PAS = Power Assisted Steering
T = Tensioner pulley
WP = Water Pump
1. Viscous coupling removal (lock the viscous coupling).
2. Lock the ancillary drive belt tensioner.
3. Lock the coolant pump.
4. Remove the coolant pump drive belt.
5. Remove the ancillary drive belt.
6. Release the A/C tensioner if vehicle is equipped with A/C (Air Conditioning).
7. Remove the A/C compressor drive belt.
Aug 09, 2011 | 2004 Volkswagen Passat
The serpentine belt replacement
Use the (B) 1/2 inch square hole in the drive belt tensioner pulley hub to rotate the (A) drive belt tensioner clockwise and remove the (C) drive belt.106fae5.gif
The diagram should be on a sticker somwhere under the hood, on the side fender area, or near the front of the truck. Or before you remove the belt draw a sketch to remember the routing of the belt.
Mar 24, 2010 | 2004 Ford F350
Need drive belt diagram for 3.3 dodge van
Below is the diagram you requested. It's for a 3.3L with AC. If you need the diagram without AC, post back with the request and I'll track it down 4 you. Best of luck!
Greg
99 Caravan 3.3L Serpentine Belt
Nov 13, 2009 | 1999 Dodge Caravan
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Diagram of a serpintine belt on a 2007 ford taurus se car
Accessory Drive Belt adobe.gif Printable View (140 KB) Removal and Installation
  1. Using a suitable belt tensioner release tool, rotate the drive belt tensioner clockwise and remove the accessory drive belt.
  1. NOTE: Refer to the illustration for correct accessory drive belt routing.
    To install, reverse the removal procedure.
May 23, 2009 | 2008 Ford Taurus
Need belt schematic for 2006 toyota corolla
I can get you a diagram on monday but it goes from the alternator to the power steering pump then around the tensioner pulley then around the crank pulley then to the a/c compressor then pull on the tensioner to give you some slack and slip it on the waterpump.I hope that helps.Let me know if you still need the diagram
Nov 29, 2008 | 2006 Toyota Corolla
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
342 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
