Question about Canon CanoScan FS2710 Film Scanner
Lamp not bright enough in my film scanner how do I fix this?
Nikon coolscan 5000ed, film stuck, will not eject
If you switch off the scanner you should then be able to remove the grey film holder, even though the film strip will still be inside. Then, press the small button above the film entry slit to open the front of the holder. Pull up the top cover, ease the bright metal holder strip forward then lift the metal flap that holds down the film strip. At this point you should be able to remove the film strip. Re=assemble and try again.
Good luck.
May 18, 2014 | Nikon CoolScan V ED Film Scanner
Dont have the software
Go to the manufacturer website and download it. That model has a problem scanning film too much brightness and there is no way to control it. Taken apart it is simply a peek hole camera. Better to scan you film on a flatbed scanner.
Nov 28, 2013 | SVP FS1000 Film Scanner
All the slides scanned are darker than the original
The problem is internal see this website for cleaning an Hp scanner but your problem is similar http://www.willshak.com/scanner/
Apr 19, 2009 | ACI Pacific Image Prime Film PF3650 Pro...
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Scanner screen
open the top glass cover,after that u can see the lamp assy ,on the banx
ck side of that assy there are some mirrors,clean all that mirrors with a cotton bud ,fix it again n chech\
do revert
th
Jan 26, 2008 | Umax Astra 2000U Flatbed Scanner
Cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
Error message
Scanner sensor is defective,,,you need a new scanner.
Dec 02, 2007 | Canon CanoScan 8400F Flatbed Scanner
Horizontal Banding
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Jun 06, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
Canon CanoScan FS2710 Film Scanner Logo
82 people viewed this question
old marine
old marine
