Question about Dryers
Dryer runs but no heat
Whirlpool dryer runs but no heat
  • 5,911 Answers
If the dryerdryer runs but no heat - 2.gif runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please post back with your complete model number so that I may be able to provide you with better assistance. I hope you find this information helpful.
Posted on Oct 04, 2009
Why is there no heat and no timer operation?
Whirlpool & Kenmore Dryer Repair - How To Diagnose No ...
? 9:01
www.youtube.com/watch?v=JfXBiZOiC2Q
Nov 3, 2011 - Uploaded by canyonman1963 Whirlpool & Kenmore Dryer Repair - How To Diagnose No Heat - High Temp Fuse 279816 OR 279769 Test. canyonman1963.
Aug 19, 2015 | Whirlpool Dryers
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
Our Whirlpool Dryer Will not heat at all and not
Your timer may be the cause of both problems. Not cycling and no heat.
Whirlpool makes a excellent dryer and is worth repairing. Replace the timer first. If you still have a heat problem most of the other parts are around $30.
Nov 09, 2009 | Whirlpool Dryers
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Whirlpool duet dryer runs but will not heat.
do you have 240 at the terminal block on the back of the dryer if so check for continuity on the thermostats , thermal fuse and heating element
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
Dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
My Dryer does not heat
Have you checked the thermal switch? If this is bad it will run but give no heat.
Apr 01, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool dryer problem
dryer works but does not heat up
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
