typically 30 ft is the longest a wifi router can reach in the line of sight, you can inprove the range with a larger antenna on each end. I hope this helps-
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
Hi, I have a Dlink DSL G604T which is working fine on the internet but will not allow to print from...
(More)
Hi, I have a Dlink DSL G604T which is working fine on the internet but will not allow to print from remote laptop have run all set up wizards so thought maybe in router settings. Cheers, John.
pourquoi que je suis pas capable après plusieurs fois. sa déja fonctionné...
(More)
pourquoi que je suis pas capable après plusieurs fois. sa déja fonctionné mes la sa va pas bien du tout...merci
