Question about Sony Cyber-Shot DSC-T1 Digital Camera
The screen is black, when you turn it on it's black, when you take a picture, it's black. Everything works like it is supposed to otherwise.
When i turn my camera (cannon powershot SD1100 IS) on the screen is black like it can not see through the lens. I can still see all of the menu options on the screen. If I try to take a picture it will...
This could be a firmware problem.
First, check your screen settings, should be in the setup menu. You may have the screen switched off, often used as a power save option.
Secondly, if its still under warranty, go back to the vendor and ask for a replacement, repair or refund.
Finally, You could try the Canon website, this is the page for the ixus105:-
http://www.canon.co.uk/Support/Consumer_Products/products/cameras/Digital_Compact/Digital_IXUS_series/IXUS_105.aspx?type=faq&page=1
Here are manuals, software download and a faqs page which may help
Apr 18, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Everything that is supposed to be black is showing
Hi,It sounds like a problem with the color wheel or DMD board. The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will hear ,humming,buzzing,high pitch noises ,you might also experiment color distortion ,black and white picture. This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 29, 2010 | Televison & Video
On my Envy 2 the exterior screen has turned white with 2 black leaves on it. Otherwise the phone works.... can this be fixed?
some of them is screen savers otherwise your front screen has shattered without you knowing. I am would have to see a picture to be sure. and if it is a screen saver just go into your internal phone options and change it
Jul 15, 2009 | LG enV VX9900 Cellular Phone
Same problem. screen is black when turned on. where can i repair?
Our camera when you turn it on has a blank screen and you cannot take pictures. You can review pictures and see the different menu modes, but the screen is otherwise black
Jun 21, 2009 | Canon PowerShot S1 IS Digital Camera
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Screen is Black, light I'm in a dark black room black
Same problem as you described. I haven't figured it out yet.
Jul 20, 2008 | Samsung L700 Digital Camera
Screen is blank or black
it maybe sounds a little like a problem in explorer.
try to start you computer up, press F8 within the windows loader appears. then select :start up the same way as last time it worked.
now it should work. if not then format the pc.
if you have a lot of important stuff on it you can download the ubuntu livecd and use it the get all of your stuff out of the disk.
hope that works.
CS.
May 15, 2008 | IBM ThinkPad A21m 2628 Notebook
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Black screen when I turn the camera on
You could be suffering from a frozen Iris. This is the part of the lens which varies the amount of light entering the camera. Or the lens cover may not be opening when you switch on. Have you tried pushing the middle button of the 3 which run vertically on the rear of the camera below the mode switch. I had one on my bench a few weeks back which had an intermittent black screen. It started of as black and when I stripped it, cleaned all contacts and put it back together it the flashed on and off. I then stripped it again and went over every cable associated with the lens, CCD and video board checking them for breaks and recleaning them and bingo, everything came good. I have another 72 at the moment with a similar problem, I fixed the same way but got left with lines running across the picture. P72's aren't the best cameras picture wise and are close to the most troublesome, at least around here. For any of the above faults I'd recommend a visit to your local tech. Good luck. BMW
Jun 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
135 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
