Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Cool Blue) with 5x Optical Zoom + Card Reader + Niko
Nikon Coolpix S550 camera monitor blank
I have a Nikon Coolpix S550 camera that dropped on our hardwood floor when I turn the camera on the monitor is a blank/black screen. Can anyone tell me what to do to restore the monitor image?
Agent Allan
  • 480 Answers
SOURCE: My new Nikon Coolpix S550 will not turn on.
Hey jeanjoy,
I would have it sent out for service. This camera comes with a 1 year parts and labor warranty, and you can bring it to any Best Buy™ store and they can send it out for service. You can also contact the manufacturer and they might be able assist you.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Apr 23, 2008
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Posted on Aug 19, 2008
  • 102366 Answers
SOURCE: How do I import pictures from my Nikon Coolpix
You can either connect the camera to the computer using the supplied USB cable, or remove the SD card from the camera and insert it into a card reader attached to the computer. The card reader is the preferred scheme, as it does not drain the camera's battery.
Posted on Dec 27, 2009
  • 11967 Answers
SOURCE: I drop the Nikon coolpix S10 on the floor and it
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 11, 2010
Testimonial: "My Nikon coolpix S10 was firstly can took photos sometime and sometime showing lens error. But now it show only lens error every time I start on "
SOURCE: my computer won't recognize my nikon coolpix s550
i want a digital camera drive
Posted on Mar 04, 2010
S80 monitor blank
If it was that easy, there would not be any repair shops. But try ifixit dot com, to see if they already posted a repair tutorial for your camera.
First try to remove the battery for a minute or so and then replace it, closing the battery / memory card cover correct.
Mar 21, 2014 | Nikon COOLPIX S80 Digital Camera
When connected to my macbook, my Nikon Coolpix S55...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or iPhoto or any other photo cataloging program.
May 20, 2010 | Nikon Coolpix S550 Digital Camera
The self timer on my Nikon Coolpix S550 will not
Isn't there a button on the camera with a picture of a clock? Push that to reach the proper setting menu.
Jan 22, 2010 | Nikon Coolpix S550 Digital Camera
Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
Sep 28, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
I dropped my Nikon Coolpix in the river, it will not turn on now, is it destroyed? It is a Nikon Coolpix S550.
Yes. Water does an amazing amount of damage to the electrical and chip inside a camera. You may be able to get it repaired, but the cost will be comperable or greater than purchasing a new camera. Sorry, I wish I had better news for you.
Jul 15, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S550. Installed Nikon Transfer..won't work.
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo management program, such as Picasa.
Organize edit and share your photos
Dec 08, 2008 | Cameras
Nikon Coolpix S550 10 Megapixel Digital Camera (Cool Blue) with 5x Optical Zoom + Card Reader + Niko Logo
73 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
