Question about Cameras
Screen displays card error card will work in another camera also when a new card was put the same message appeared
4 Suggested Answers
Habubnik
  • 114 Answers
SOURCE: The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Posted on Aug 29, 2005
  • 244 Answers
SOURCE: Card error, no card inserted
It is possible that you camera having trouble to the card port. If you are familiar disassembled camera you need to use a circuit tester. Try to resoldered the card port on your camera just to insure the connectivity working.
Just ask near electronic shop to resoldered the card port if you are afraid to avoid damage to your camera. Sometimes this because of a capacitor could no longer supply value of voltage inorder to detect the card.
I don't beleived that this was not affected with a viruses because as what you stated you can used the card through card reader with computer. So that mean's the internal problem is from your camera.
Please let me know any update.
Posted on Nov 30, 2007
SOURCE: olympus camedia D-395
take the card out and blow on it then blow into the slot i had that problem and this solved id for me
Posted on Feb 20, 2008
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
When I install a new SD card in my Canon PowerShot A540 it displays Memory Card Error Card Locked. I have moved the tab on the card and it displays the message regardless if the card setting. What
it seems to be the memory card slot is damaged normally 9 contacts connect with MC if any of it doesn't contact, will not work, open and takeout card slot if the contact is bend align it to touch the MC's contacts.
Sep 02, 2017 | Canon PowerShot A540 Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
Problem with the CF card
Do both of these CF cards still function when you connect them to the computer?
Inspect the CF connector on the camera using a flashlight (torch). It's possible that one or more pins on the connector may have been damaged, somehow. If this is the case, the camera will need to be repaired.
Can you still operate the menus after the error message appears? If so, use the menus to reformat the card (see the manual for instructions).
Aug 08, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Nov 30, 2007 | Olympus EVOLT E-500 Digital Camera
Olympus camedia D-395
Oct 08, 2007 | Olympus Camedia D-425 / C-170 Digital...
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
"Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
