Question about Garden
Have craftsman chain saw, runs ok for a few minutes then dies. found broken gas line.replaced fuel line,air filter,spark plug, checked muffler, also mixed fresh gas.eng acts like its out of gas. leave it set for a few min it starts again then repeats the above symptoms. could it be a gas tank vent?
    President:
  • 2,220 Answers
The plugged vent gets my vote. Loosen the fuel cap when it starts to starve.
All Poulan IPLs (exploded parts list) are here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find your model, what little fuel system detail there is can be found on it. HTH
Lou
Posted on Oct 04, 2009
  • dontbother10
    dontbother10 Oct 04, 2009
    I should hve said 99.5% of Craftsman saws are made by Poulan.
Craftsman 32cc/170 mph leaf blower. Why does it die after a few minutes running?
Is this a consistent situation? Starts, runs then dies after a little while?
If so, sounds like carburetor/fuel pump (which is a one way diagraphm) issue.
Take carburetor apart, and also obtain a rebuild kit for it. Clean it well, compressed air through all the jets, replace the parts from the kit and reassemble. Re-install back onto unit.
Also... Replace Spark Plug, fuel filter and clean the spark Arrestor screen at muffler.
May 26, 2015 | Craftsman Garden
Chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
May 22, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a Craftsman 2.5 Turbo 18" chainsaw. Yesterday it would start and run briefly and the die. I changed the sparkplug and cleaned the air filter and now the saw will not start. The plug is...
Seeing a lot of fuel line problems due to ethanol. Make sure your fuel lines and primer lines are in tact. If the fuel line has broken, you may also need to clean out the inlet screen in the carburetor which can also become clogged.
Feb 12, 2011 | Craftsman sears 18" Chain Saw Chain (...
Have a craftsman # 358.350880 saw will not accelerate and lacks power
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Check for proper chain oiling by running the saw at speed for several moments with the bar tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Aug 13, 2010 | Craftsman sears 18" Chain Saw Chain (...
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Jul 13, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Craftsman chain saw. Won't restart after running for long time.
First check is for spark at the plug when it won't fire--it should be blue and snappy with a fresh plug set for 0.020" gap. If not, then remove the flywheel side cover, turn the flywheel magnets to underneath the ignition module. Use a thin business card for a gap gauge and insert it into the space between the magnets and the module poles--loosen the screws holding the module to allow the module to stick to the magnets, then re-tighten the screws. Recheck for spark. If now ok, try to start the engine. If this made no difference, then replace the ignition module and use the same install as before. If you originally got good spark, place little fuel mix in the plug hole and retry start--it should at least pop several times. If so, check the fuel filter, air filter and muffler for plugging. Check the condition of all fuel lines. Make sure the carburetor fasteners are all tight. Finally, the carburetor lower diaphragm may be hard or cracked. Make sure the saw body is not getting overly hot-- it may need cleaning with compressed air to recover proper cooling. Hope some of this helps!
Jun 22, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
Craftsman gas blower no start
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
No full speed then dies
1) spark plug
Chain Saws:
Remove Carburetor
Nov 23, 2009 | Craftsman 4 Cycle Blower/Vac
Will not run (dies) at full speed
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 20, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
223 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
