Question about Sylvania 6719DC 19 in. TV/VCR/DVD Combo
TV wont stay on
The tv ate a tape that was in the vhs compartment. after removing the tape the tv shut off. now when the tv is turned on, it only stays on about 5 seconds then turns off. is the tv trash?
    Novelist:
    Champion:
  • 211 Answers
The vcr carriage was probably damaged ( broken gear or carriage gear, etc ), As for repairing it, it may not be worth it and chances are, you won't find a new carriage for the unit. I have, in the past, disarmed the VCR unit and at least the customer could watch the TV. Thats not possible in every set, but it seems to work in the majority of them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
My tv won't stay on after I turn it on, it only stays on for a few seconds then shuts itself off,
Posted on Feb 17, 2009
Have MAG TV model CT270MW8 27 inch that wont stay on unless a VHS tape is in and then only if VHS player ejects it (automatically) and then reiserts itself. The tape then/must stay in
You have a mechanism problem in the player---it has two sensors in the tray and they detect the tape is in and load it.
If the unit was working it will each time turned on cycle the mechanism to see that it functions--shutdown if not functioning correctly.
Apr 28, 2012 | Televison & Video
Small motorla color tv vhs tape is stuck in tv
Remove power to the set - unplug the wall outlet. Remove the screws that attach the back cover. Remove the cover. Remove the cables that connect to the VHS drive to the TV main board. Remove the mounting screws that attaches the VHS drive to the set. Remove the VHS drive. Manually turn the take-up gear which is near a motor to allow the tape to mechanically eject the tape - do not force.
Feb 19, 2011 | Televison & Video
Trys to eject movie, fails, then shuts off...
the tv must unscrew the cover turn the power felds around for vcr cage for sensor the tape will pop out.push the eject button doing this.
Aug 13, 2009 | Funai F3819D Combo
Symphonic Model# SC319A
did you try leaving a tape in the vcr?mine did that and when i left a tape in it worked fine. good luck.now i cant get a tape out...lol
Jul 17, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
My tv shuts off
I picked one up in the trash 2004 model 27MDTR20/17. I turn it on and it shuts off. I opened the back and pulled the DVD/VHS board out. I removed a metal cover on the VHS housing (three screws). There was a broken clear plastic rod and one of the gear stop plastic cords (on the left side) was ripped where it attached to the front metal bracket through a hole in the plastic tab. The plastic chord has a piece of white felt like material attached to it. I epoxied the plastic rod back and put a piece of tape over the broken plastic end of the cord. The tape was folded over the edge of the plastic and then wrapped back on itself. I trimmed the outline with a scissor and poked a new hole in the end where the original hole was under the tape. I attached the chord back to the metal bracket. The problem was still there, the power would go off after a few seconds and the VHS gear train would make a slight motion like it was getting stuck. I then removed the mounting screws on the VHS housing and lifted it off the board slightly (ther are 2 screws that need to be removed from the far side also). There is a small gear under the right side of the board that was not aligned with another gear. The alignment is between a pin on one gear and a hole on the other. After I aligned them I reassembled the unit. The power stays on now only if I leave a tape in it but the DVD and VHS seem to work. My problem now is that I can only select AUX and channel 2! On well thats my next battle. Good luck.
Jul 09, 2008 | Philips Magnavox 27MS343S 27" TV
My Tv is turning off by itself
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sylvania 6719DC 19 in. TV/VCR/DVD Combo Logo
492 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
