Konica Minolta magicolor 2430 DL Laser Printer
Problem for Konica Minolta magicolor 2430 DL Laser Printer
When I print in colour there is a white streak
By jvsumner on Oct 04, 2009
When I print in colour there is a white streak from top to bottom about 5 cm from the left hand side
Best Solution
posted on Nov 24, 2009
Very Helpful)
TimmyQMS
Rank: Master
Rating: 92%, 3 votes
If you remove the drum, inside where the drum is a small glass panel if you clean this the white line will go away.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Yew, this is what I did and it cured the problem. The toners had leaked and made a spot on the laser. Thanks " - jvsumner
Solution #2
posted on Oct 12, 2009
Very Helpful)
jdks
Rank: Apprentice
Rating: 100%, 3 votes
- remove all cartridges
- clean all leaked powder on the cartrtidges and inside the 4 cartridge compartiments with a vacuum cleaner
(don't touch the powdered roll on the cartridge!)
- deep inside the printer you will see a glass-strip. You have to clean this strip carefully. Because of powder, that has leaked from the cartridges, the laser-beam is dimmed. This causes the white streak you mentioned!
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" Thank you very much. I shall try this solution and probably will have my printer working properly again very soon. " - jvsumner
Popular Solutions for Konica Minolta magicolor 2430
Questions and Unsolved Problems for Konica Minolta magicolor 2430
Do you recommend Konica Minolta magicolor 2430 DL Laser Printer?
Answer
Answer
when i print, it does not print anything. page is blank or with some lines. sometimes, when it... (More)
Answer
I cannot get the black toner cartridge to come to the front in order to replace it. The menu says... (More)
Answer
Can not find install drivers. Tried using the drivers from the website to no avail
Answer
Image is begins aprox. 1.5 inches from top of page and cutting of image on bottom. Mismatch size... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
