Question about Whirlpool Duet GHW9150P Front Load Washer
It won't come back on.
I had a f21 error. I turned the machine off and unplugged it according to the manual, but now it won't power up at all. I have unplugged it again to see if it will reset, but so far this has not done the trick. Help, I have wet clothes in my washer and company coming for Christmas.
    Sergeant:
    Champion:
  • 262 Answers
Take the front lower cover off and there is a tech sheet in there look at it and it will tell ya what the code is for and how to correct it I cant remember this code off the top of my head and all the brands have different codes.I have about 5 three ring binders of tech sheets in my van if you cant find it i will look it up for you once you find this sheet clear the code and run it through diag.mode the sheet will tell you how to put in in self or automatic try auto. good luck
Posted on Dec 22, 2007
Kenmore he2 plus washerwashing machine turns on but cycle does not engage
The error F21 is a long drain error and usually the drain pump is not working or the filter is clogged. Remove the lower kick plate and clean the filter. Post back your results.
Jun 28, 2013 | Washing Machines
What is Error Code F21
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Feb 24, 2013 | Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Keeps on coding F21 - we have adjusted the hose several times but still seems to be giving us problems
Hi
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
What is an F21 flashing? My washer will not turn off or anything. It is humming and flashing F21. Thanks
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
Thank you !!
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F21
F21 is:
LONG DRAIN
NOTES:
After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed.
Possible Causes/Procedure
kinked.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
kinked.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error code F21 - thanks for your help
The F21 error code is an indication that the unit has too long of a drain out condition. If the control calls for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Clear pump of debris. Tilt machine. Take off front panel. Unscrew large white drain plug. Remove debris.
Unplug from power source...remove front lower panel (3 sheet metal screw wirh 1/4" drive head located on the lower lop of the panel)...open pump strainer (looks like a large stove knob, Turn it counter clokwise, lookout! lots of water will gush out... back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump)...re-assemble, plug to power, and turn-on. That will help get rid off the debris.
It can be done if you are patient and able to figure out how the plastic thing comes apart. Good luck!
May 09, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
