Question about Acer Aspire 5315 Notebook
Hey i can not get connected online i use the dial up method. i believe my modem is bad but i havent had my laptop a year yet. is there a number so i can speak with someone.
  • 408 Answers
It may be bad or not installed or not using the right drivers.Uninstall the modem in device manager then restart the laptop.It should reinstall it on reboot.If not go to Acer get the correct drivers including the chipset.Install the chipset first then all the others.Make sure you reboot after each driver is installed.If the modem still does'nt work it may need to be replaced at that point.
Posted on Oct 10, 2009
I want to use my blackberry 8520 as modem to my laptop
Yes. I used to do that before 3G became popular.
The Dial Code depends on the country and carrier. I used *666#
Set Up a Dial-up Connection
You'll need to set up a dial-up connection on your Windows machine to use the BlackBerry modem. When you installed the BlackBerry Desktop Manager, it should have automatically installed the modem drivers to use with your device, and you should have a modem called "Standard Modem" in the Phone andModem Options section of your Control Panel. The drivers are located in the following folder: C:\Program Files\Common Files\Research In Motion\Modem Drivers. Use the following steps to set up your connection:
  1. Connect your BlackBerry to your computer using the standard USB cable that came with your device and start the BlackBerry Desktop Manager software.
  2. Go to the Control Panel, then Network Connections, and select Create a New Connection.
  3. Select Connect to the Internet, then Set up my connection manually, then Connect using a dial-up modem, and select your BlackBerry modem from the device list.
  4. Choose a descriptive name for the ISP Name (e.g., BlackBerry Modem Connection).
  5. Enter the phone number for your service provider. You'll probably have to check with your carrier to get the right number. For Cingular and other GSM carriers (AT&T, T-Mobile), it's *99#. For CDMA providers (Sprint, Verizon), the number will be #777.
  6. The username and password will vary by carrier as well. Cingular just accepts null values for both fields.
  7. Complete the wizard, being sure to deselect the "Make this the default connection" checkbox.
How to use Blackberry Curve phone as modem O2 Guru TV
Jul 16, 2016 | RIM BlackBerry Curve 8520 Smartphone
I have a netzero dialup and when i try to establish a connection i get "dialing, redialing in 5 seconds, dialing..., unable to establish a connection" How do i establish a connection?
If you turn your sound up on the computer, do you hear a dial tone? Does it then begin dialing? If not you may have a bad modem. Try dialing the ISP's number with your phone, it should dial in and you should hear various beeps and so on, if not the ISP is down.
Dec 24, 2014 | Compaq Presario 2100U Notebook
Can I download modem on dell laptop
Most of the time on laptops if there is no phone input for a modem you cannot just plug in and dial up. The process i use at home for my pc is dialing through my cell phone. If your carrier will allow you to tether your phone without extra charges check your phone manufacturers website for modem software. You then just connect your phone through a usb cable and set a internet connection matching your carriers instructions. Another solution is dificult without networking knowledge but you can set up a home pc with a wireless antennae as a ad-hoc server through internet connection sharing and then allow your laptop to connect through the "server" pc.
Apr 07, 2010 | Dell Computers & Internet
I have a optus usb modem plugged into laptop using vista. i am trying to connect to the internet on my playstation 3. i have enabled ICS and entered the IP address, DNS numbers from the command promt...
Depending on if you're using a Dial-Up Connection or a Broadband Connection, the solution is quite different. If you are using a Dial-Up connection, the PS3 will have to do the dialing. In your case, I do believe that you are using an Ethernet (Broadband) Connection which is always on. In order for your PS3 to get Internet access, you will need to get a router and install it before you can get online with your PS3.
Mar 20, 2010 | Computers & Internet
I have a Toshiba Satellite A305-s6916,modem is not connecting
Get a external modem and try that, But first try and connect network.Start- Control panel , delete current Network and make new one. If its Vista it will repair itself. just follow the bouncing prompt
Jul 30, 2009 | Toshiba Satellite X205-SLI1 Notebook
Windows cannot detect a dial up modem
have u tryed to reboot your modem ( pull the power out )
or the reboot button depends on what modem u using
make sure all cables are connecting
if they are then try testing the cables if u can
update the software and drivers, firmware
Jan 27, 2009 | Computers & Internet
Modem, Dial Up Connection Problem
here's some help...go to : start menu,all programmes,accessories,communications and to hyper terminal..type in test, and click o.k.,make sure all the settings are o.k., type in your mobile or your second land line number to test if the modem dials that number.if that test works then contact your i.s.p to check on your account.
Sep 03, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Apple user attempting to fix dad's dell laptop windows xp home edition
I'm confused because you say your trying to make a lan connection on the dell laptop but your connecting it via firewire into a DSL modem. doing this method would be a WAN connection and not a LAN connection. To make a lan connection you need to connect the laptop via network cable (or wireless connection) to a router that is connected to your actiontek dsl modem.
I can help you connect the laptop to the internet but 1st i need to know if your trying to connect it to a router or did you want to do a wan connection from the dsl modem.
Thanks,
Brad Nelson
Mar 15, 2008 | Actiontec (GT701WG) Wireless Router
Cannot get Modem to dial, but tests okay
Tryr another phone jack in your house if you havent already. or plug in a normal telephone to the outlet your computer is hooked up to and make sure the line is good.
Also did you recently add voice maiol to your phone line?? if you pick up the phone and it goes dt-dt-dt-dt and then gives a dialtone the delay causes the computer to not know it is reaching an outside line.
Finally do you have technical support with the company you pay for your internet service??? they can probably help you narrow it down as well easier than us guessing online.
Jan 14, 2008 | Compaq Evo N1020V Notebook
No WModem?
You can dial-up to internet via BT connection. Firstly, pair hw6500 from BT enabled notebook/ desktop, then establish Dial-Up Networking and enter *99# as the dialing number
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Acer Aspire 5315 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
