Question about Casio Exilim EX-S600 Digital Camera
Canon pc1106 telescoping lens is stuck half open, camera was droped no visible damage but first time turned on after the drop the lens opened half way and stuck there will not open the rest of the way or close
t00nz
  • 4738 Answers
SOURCE: camera lens cover is sticky
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 25, 2007
t00nz
  • 4738 Answers
SOURCE: lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
  • 374 Answers
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Posted on Mar 30, 2008
SOURCE: casio camera lens stuck
i droped my camra and now the lense is like stuck where can i go to get it fixed
Posted on Jul 27, 2008
worldvet
  • 859 Answers
SOURCE: Nikon D50 dropped and not working at all.
Parshiv makes a good suggestion. Let us know.
Worldvet
Posted on Oct 19, 2008
Canon A540 E18 error
You don't want to take it apart. Wayyyyyy too many parts and steps. I bought a used one with the same problem, lens was stuck half open and out of alignment, it was dropped. I got it working well in about an hour.
I tried all the described tricks, plus a few others.
#1 get a strong canister vac or shop vac, and put the end of the hose right over the front of the camera and turn it on for a few seconds, and turn it lens side down. This will remove any grit in the gears and may pull the lens itself all the way out.
#2 if the lens is still stuck try rotating the outer collar gently both ways until you hear it click into place. If it does, look at the alignment of the inner barrel to the case. the lens will never fully retract if it is out of alignment, if it is you will have to force it back onto the gears it should be on.
If it was dropped resign yourself to the fact you must at some point nearly break those plastic gears inside to get them back where they need to be, and there's a fine line between forcing and breaking it.
Just remember you'll have to get the lens closed and aligned before it will work, closing it is a proces of both rotating the outer collar and gently wiggling the inner sleeve closed. Before it will close it has to be straight. Once it its closed put a fresh set of batteries in.
This whole E18 issue is not as complex as people might think, you just have to be reeeeal gentle with that lens assembly when it's extended.
Oct 03, 2009 | Canon PowerShot A540 Digital Camera
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot A630 Digital Camera
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 15, 2008 | Canon PowerShot S2 IS Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
489 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
