Question about Frost Inglis 17.6 Cu. Ft. -Free Top-Mount Refrigerator - Silver - IT18SKXRD
Inglis Refridgerator Hello I have a new fridge that is 3 mos. old. Since it's arrival I have been dealing noise issues. The fan is TOO loud and runs for ever. I just put groceries in the fridge at 2:30pm and the fan has still not shut off. I had the same problem yesterday. The fan started at 3pm and stopped at 7:30pm. Is this normal? The noise just gives me total grief. Can I open the back of the freezer and remove the fan? Thank you. Linda.
  • 32 Answers
No the fan must stay or your Fridge will not cool, I hear this same problem from a lot of people that have new Fridges. all new fridges are louder that the older ones, check to see what setting you have your control set at. Try turning it down to 3 or B this will make it run less. other than that, if it is cooling ok. then that is just the way it is. I hope this helps
Posted on Dec 22, 2007
My 18 year old top freezer Inglis refridgerator has started to clunk. This noise began a couple of months ago. The clunk is fairly loud ( heard over the TV) and happens once every couple of hours. The...
The clunking is because the compressor has a broken mount and it clunks when it shuts off... this will eventually cause bigger problems, but probably you will need to replace the compressor to fix it...even so just check that a bolt did not come loose and that it may be a simple fix...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
My 2002 Olds Alero the fan is loud and blows no heat
have to remove blower motor to clean out ,most of the time there is leaves in it.
Oct 11, 2009 | 2002 Oldsmobile Alero
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Compressor is hot and fridge makes a cllicking noise
You need to replace the part that plugs drectly onto compressor. You can use a 3-in-1 or a new sart relay. When tou pull thwe old one it will sound like a box of matches.
Mar 29, 2009 | Whirlpool GS5SHAXN Side by Side...
Whirlpool Gold Fridge w/ freezer on top. LOUD banging noises.
I think the banging means the compressor is shot. (more like a load "clunk"). I had the same noise on a dehumifier.) I dont' think replacing a compressor is a DIY, and doubt it is economically efficient. But I leave that to the specialists to comment on. Check Craig's List in your area - you can get a good deal for a few hundred bucks.
Also, the "clanging noices" is probably the fan blades for the air circulator that moves cold air from the freezer to refrig compartment. Check the online manual for your model (exploded parts view) to see where it is located and if it is readily accessible by taking out a few screws inside the refrigerator. Might be more than one fan - open the door when it happens and see if you can locate where the noice is coming from. This is a plausible DIY - I did it only my old fridge - replacement parts were cheap. But you might even be able to just reallign the fan blades so they don't clang.
Oct 26, 2008 | Refrigerators
Refridgerator (Bottom Frzr-French Door) not getting cold....Freezer is o.k.
could be a few issues, id open teh freezerdoor at looka t back panel id tere frost building up??? if so youhave a defrost issue, can you here the fan in freezer conmpartment spinning you may have a bad evap fan
Mar 16, 2008 | KitchenAid KBFA20ER Bottom Freezer French...
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Refrigerators Logo
248 people viewed this question
Top Frost Refrigerators Experts
Charles T Nevin
Charles T Nevin
Mike
old fart58
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
