MY IPOD IS BROKE AND I WANT TO FIX IT SO I WANT TO SEE PICTURES OF WHAT AND HOW IT LOOKS AND IS SUPPOSED TO BE PUT TOGETHER CORRECTLY INSIDE!
  • 13,433 Answers
Hi which ipod is it? touch? nano? There is a 5$ diagnostic service that you can send your ipod to and they will tell you what is wrong with it and how much it will cost to get it fixed, I can help you but you could first tell me which ipod is it, also the serial number might come in handy. thanks
Posted on Dec 09, 2009
I own an iPod touch 4th gen about a year ago I broke the screen I just desided to fix it the other day so I orders a screen and LCD to put it all back together is almost all together but when I try to turn...
It seems to be a faulty connection?
Did you check all the ribbon cables and make sure its all connected securely to the mainboard? Sometimes after not being powered up for so long the RAM goes bad and you may need to reset the ios in iTunes. You'll have to put you ipod in recovery mode and patch it in the iTunes recovery menu. If you don't succeed, you didn't connect the wires properly in the ipod touch or in some case static could have harmed your circuitry.
May 24, 2014 | Audio Players & Recorders
Kenmore heavy duty washer model awiz wiring diagram
There is a wiring diagram inside the washer usually inside the control panel.
Jun 26, 2017 | Washing Machines
Can some tell me if they have a picture of the inside on the switch my fell apart need put back together?
If you click HERE you will be taken to a web page of part numbers and the exploded view diagram's of the area of the washer the parts is located in.
Dec 15, 2011 | Roper RAS8445KQ Top Load Washer
Opened the wrong compartment to change the battery and the gears fell out. I need a picture of gears to get it back together.
This is Bertie the bus. It stopped working so I took it apart. The Philips head (criss-cross) screw gives access to the battery. You're not supposed to take out the screws with triangular socket heads. If you do everything falls apart and you need an engineering degree to know how to put things right.
This battery holder is clear plastic, instead of black, so I can see what is happening after assembly. The red wire broke off the motor while I was looking at it so I had to resolder it. The red plate on the upper part swivels, it has an arm that holds the clutch plates together when the switch is on. The long white arm at the upper end of the gear assembly should fit into the slot of the red swivelling plate. I think it is supposed to be a noise-maker.
Bertie is supposed to go on the road, not the track and there is a plunger that cuts out the power when it is on a wooden track. This stopped working so I jumpered it to be always on.
Good luck.
Aug 25, 2011 | Seth Thomas Thomas & Friends Percy Train...
My throttle continues to stick. The motor races and it sounds like the engine is about to explode because of its speed. I opened up the handle and the spring seems out of place. When I squeeze the trigger...
You should see some small wear marks inside the handle where the spring is supposed to rest. Also, check the throttle cable where it exits the plastic engine housing and goes to the throttle plate on the carburetor. Make sure it is connected correctly and not binding on anything on the way to the carburetor. There really aren't any diagrams or pictures available on the net of the insides of a Ryobi weed-trimmer's throttle trigger and spring.
When you squeeze the trigger the steel cable should move, the cable housing should NOT. If you look closely, you will maybe see how it works and all goes together. It is not that complicated.
May 21, 2011 | Ryobi Garden
Fills the hums loudly
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
Jan 08, 2009 | Kenmore 15864/15862 Top Load Washer
Putting a kenmore electric dryer back together
Your best bet since this will be hard to do without looking at it is to call a local repairman. There are too many things left to chance.
Dec 07, 2008 | Kenmore 63942 Dryer
Putting pictures on my ipod
ask in the shop because the ipod maybe broken.
Mar 08, 2008 | Apple iPod MA446LL/A MP3 Player
Screen looks melted in the inside
you have physically damaged the lcd screen inside. you must replace this, or get used to the screen being impeded visually
Oct 28, 2007 | Apple iPod nano
Tower Speakers
mine broke too...what I did was, I mount them together like it was, then I wrap halfway with aluminium scotch tape (you can find it in any electrical shop)..after that, I just mount the screw and tighten it ..it works for me.. :)
Sep 25, 2006 | LGDVT418 System
20 people viewed this question
 Grubhead
Grubhead
