Question about Garden
Can you tell me how to rewind line on a mcculloch whipper snipper model number mt250cls thanks
evwood
  • 50 Answers
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
Posted on Jan 03, 2009
  • 718 Answers
SOURCE: Looking for a manual.
You can download the manual from;
http://www.stihlusa.com/stihl_ownersmanuals/FS_45_46_Manual.pdf
and yes since it's second hand replace the spark plug.
Posted on Apr 23, 2009
  • 4 Answers
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Posted on Jul 16, 2009
SOURCE: my whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Posted on Mar 01, 2010
SOURCE: I have replaced my ryobi whipper snipper fuel
I have had exactly the same experience, and then also replaced the primer bulb, messed around with the carby mixtures, but so far it will not run for more than about 3 - 5 seconds! I have yet to resolve this problem.
Posted on Feb 28, 2011
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
How toremove spool ?
Remove the snap-on cap (Orange cap) on the bottom of the unit. Under that is a REEL (no doubt empty) and slide it out. If you have twine, rewind your own; or get fully ready to go spools and insert in the area where you remove the original. You need to Feed the new line (end) through the small hole from inside the spool area to the outer exposed portion of the whipper.
May 10, 2014 | whipper snipper Garden
Replace trimmer line on electric Green Machine Whipper Snipper
wind your line in the direction indicated on the spool there is usually an arrow which shows the way to rewind your line
Dec 15, 2013 | Garden
How do you replace the pull cord on a McCulloch whipper snipper Mt325CLS
Generally this happens either because the spring has broken, or the mechanism is full of dust and rubbish that jams everything up. While I am not familiar with your particular model, they all tend to be very similar. You undo a few screws to remove the cover and expose the pull cord mechanism. If the spring is broken, take note of where the ends are connected to, buy a new spring and then put it back the way the old one came out. This is not as easy as it sounds, as you need to wind tension on it. It in doubt take it to the dealer. The job will take less than half an hour so shouldn't cost much.
Nov 28, 2011 | Garden
Q. Need a replacement head for the McCulloch Whipper Snipper model MT255CLS.I live in the Newcastle area and would like to now where your distributor for this poduct in located.Availablitiy and an avergae...
Lowes has replacement universal heads but check the height where sring exits head to see if it will hit excess string cutter on guard .
Jan 16, 2011 | Garden
I need an owners manual for McCulloch 100 series Eager ****** chainsaw
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
A complete parts list using the "IPL Number" can be found here:
K&T Parts House
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
ArboristSite is where I found both my Mac 110 and Power Mac 320 operators manuals.
Dec 13, 2009 | McCulloch Garden
How do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
Oct 22, 2009 | Ryobi Garden
Garden Logo
206 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
