Question about Maytag Dishwashers
My maytag dishwasher model no. DWU6502AAB does not completly drain after it finishes its cycle
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
SOURCE: Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Posted on Feb 26, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher will not drain
Hello Tom_Simmers,
Here is a link with exploded views and parts lists for your dishwasher for reference however based on your description, have you made sure you don't a blockage in the check valve? That's part of the pump drain assembly. http://www.pcappliancerepair.com/model-display.php
You may also have a problem with the pump itself so the documentation on the website will help you evaluate that.
In many instances, its just a blockage of food byproducts inline with the drain system so chances are thats what you will find.. Good Luck on that.
Regards,
Rick
Posted on Dec 02, 2008
  • 439 Answers
SOURCE: Maytag dishwasher that won't drain when finished
Ok, I assume you are the one from earlier. There are only two other reasons for this to happen, ok three but one should be clear. The sink is backed up or backs up as the dish washer drains. I doubt this is it as you already cleaned the hose. The other reasons could be the drain solenoid is not working or the drain pump itself. Other than that it would be the timer, but again that is highly unlikely. The reason you are not flooding is there is a float switch inside the dishwasher that lets it know how much water is in the tub. You can "jiggle" it (the float) and see if that helps.
Posted on Jun 22, 2009
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Maytag gold dishwasher model GU2400XTP03 Ser# Fs0606107 Will NOT DRAIN
Hello
Do not open the dishwasher until the cycle completes. A green indicator light on the front of a Maytag dishwasher will let you know the cycle has completed. If you open the dishwasher before the cycle is over, close the door and press "Start/Resume."
Remove the knockout plug from the disposer inlet if the dishwasher is connected to a food disposer. Place the tip of a screwdriver along the edge of the knockout plug, which is on the side of the disposer. Tap against the head of the screwdriver with a hammer until the plug comes loose.
Inspect the drain hose for kinks. Make sure it is not bent or pinched in a way that would impede the flow of water through it.
Use your hands to clean food from the drain in the dishwasher. A buildup of food can block the drain and not allow water to freely flow from the inside of the dishwasher.
Open your breaker box and check to see that the switch that controls your kitchen appliances is flipped to the "on" position. A switch flipped to "off" means your appliance has no electricity. The dishwasher will not drain without power.
Sep 11, 2011 | Dishwashers
Maytag Model # MD87609AWB3 after rinse cycle it stops. I have to push button to finish drying cycle
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Maytag Dishwashers
MAYTAG JET CLEAN DISHWASHER MODEL # MDB7100AWB, WILL NOT RUN THROUGH CLEANING CYCLES, TRICKLES WATER UP FRONT DRAINS VERY BRIEFLY, REPEATS THIS FOR A PERIOD NEVER KICKS INTO THE WASH CYCLE, THEN COMES UP...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 ;';
Aug 24, 2010 | Maytag MDB7100AWB Dishwasher
I have a Maytag Quiet Series 300 Dishwasher (can't find any other model number etc). The normal and high temp wash lights are steady and the Start/Resume light is flashing. I've tried turning off the power...
Turn everything off first then turn off the power at the switch. Wait 10 minutes, then turn all power back on..the electronics should reset itself..also, verify it is draining properly... cheers
Nov 14, 2017 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag Model WU482 Dish washer completes cycle but dishes remain dirty and water is laying in the bottom.
Check the hoses and air gap for clogging. Air gap is located under the sink between housing seawar line and dishwasher hose.
If no help check/replace drain valve
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-drain-valve
if no help drain pump might be faulty.
Good Luck
Feb 25, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Aug 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwashers Logo
43 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
