Question about Maytag Atlantis MAV6000 Top Load Washer
My washer stopped and will not drain. It will not turn on at all.
  • cortez1219 Oct 04, 2009
    No it just stop while it is full of water
  • Dale Gildner May 11, 2010
    can you hear the motor run?
    President:
  • 1,304 Answers
Lid switch
to empty it you can push the pin with a screw driver
hopefully you will get one good spin down
the lid switch is dead center in the console
its about a 2 on the dificulty scale
Posted on Oct 05, 2009
The motor is running but it won't turn the belt on my front loader ge washer
It definitely sounds like the belt is stretched, worn-out, and in need of replacement.
Jul 30, 2014 | General Electric Gfwh2400lww 4.9 Cu. Ft....
Tip
Appliance Repair Eagle - Maytag Washer Won't Drain
Maytag Washer Won't Drain Maytag washers are notorious for drain pump failures. The most common complaint is that it won't spin, agitate, or mainly won't do anything. The pump bearing locks up and stops the washer belt from turning. Tilt washer up against the wall, remove belt, and turn each pulley by hand. If it doesn't move, then it's locked up. Remove the front panel and replace pump. Rich Western Appliance Repair
on Oct 12, 2010 | Washing Machines
Fills Constantly
check the drain hose. Is it in the drain below the fill line of the washer?
In other words -- the drain line should be above the level of the washer lid top and in the line about 4-6 inches
Feb 20, 2014 | GE GTWN3000MWS Washer
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
Error code f 21, what does this mean?
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
May 18, 2010 | Washing Machines
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
169 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
