Question about Rainbow E series Canister Wet/Dry Vacuum
SE Rainbow making a high pitched whistling noise
I have an SE Rainbow and it is making a high pitched whistling sound. It still sucks up dirt, though. Do you know what might be causing it to make that sound?
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Rainbow E Series Vacuum
Is there suction at the vacuum, without the hose hooked to it? If there is, then your hose may be clogged, if not, it is possible that the corrugated filter may be clogged up. You would have to remove the top to get to it.
Posted on Jan 09, 2008
Agent Don
  • 310 Answers
SOURCE: Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
  • 75 Answers
SOURCE: Rainbow SE makes funny noise
try putting water into it.if not then you should make sure the seperator is in.or is connected properly
Posted on Jun 29, 2009
Aquamate is making a high pitch sound and the brush isn't moving
Check the belt and brush roller on your Aquamate. The belt may have slipped or be broken. There also may be a build up of hair or fibers stopping up the brush and preventing it from turning.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Apr 04, 2014 | Rainbow Rexair Brush, Aquamate R2262
Sounds funny
like what.. a whistle? a sucking sound like a gasket not seated..
Mar 06, 2014 | Rainbow Vacuums
Filter whistle noise
Hi Basil,
I am sorry to hear your machine is emitting a high pitched sound. Based on the details you provided the problem may be isolated to the post motor filter, if so a new filter will be needed. We would like to help with this. Please contact our Helpline to speak with an expert:
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Sep 01, 2013 | Dyson DC25 Vacuum
The carpet attachment is turning but not sucking.
Check the clips that attach the hose to the front of the Rainbow. If one is broken, then it will leak air and reduce performance.
RainVac
www.rainvac.com
800-523-0510
Apr 22, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My vax vacuum has started making a high-pitched whining/whisting noise
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Feb 07, 2012 | Vacuums
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
246 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Robert McClure
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
