Question about Compaq Computers & Internet
Monitor probs. My monitor loads but then it goes blank with a black screen with a mouse cursor in the middle.
    Sergeant:
  • 233 Answers
Since you do not state what Operation system you are using.
Will assume what most lemmings use now. Windows.
Can you hold the F5 key down while the machine boots.
Then does Safe mode come up?
If it does, this usually means the operating system or some file(s) needed are corrupt. Sometimes you can select "last known good start up".
However this has NEVER worked for me.
If you have Restore points activated.
You may be able to restore back to a point before the corruption occured.
some help on restore points from MS website:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Posted on Oct 04, 2009
What do I do to get a screen that is frozen on a hp2010i monitor it is asking for language but the cursor on my mouse wont go to the selection
HP Monitor Problem - YouTube
? 1:35
https://www.youtube.com/watch?v=RYLaefQQdDY
Jul 22, 2009 - Uploaded by 7TimeToShine7
So I can use the monitor like I am using now but when themonitor goes to sleep I ... I tried it with a different computer and the monitor was able to re-find the ... How to fix or troubleshoot a blank or black screen not powering up ...
Monitor message" Power Button Lockout" - HP Support Forum
h30434.www3.hp.com > ... > Video/Touch
Feb 2, 2011 - 10 posts
Solved: New HP 23" monitor - HP 2310m Accidentally held down the power button too long; now I can't get the monitor to turn completely off. ... How can I turn the monitoroff completely and clear the message "Power Button ..... 8) · HP PCs - Error Messages Display on a Black Screen during Startup or Boot ...
OSD Lockout on my desktop monitor - HP Support Forum ...
h30434.www3.hp.com > ... > Boot
Dec 25, 2010 - 9 posts
If that doesn't work then go into the monitor's menu and do a factory reset. ... it looks like those button get stuck and doesnt work anymore so this is the ... OSD lockout prevents the OSD menu from opening on the screen when ...
Jan 03, 2016 | HP 2010i Black 20" Widescreen LCD Monitor...
My monitor goes blank after a while,power light still on,why is this & what can I do?
Check connection cable with videocard on your PC, unplug it and carefully plug it in again. (Turn off your monitor during this operation). If monitor goes black after loading OS (like Windows), then your screen resolution higher then monitor can support. Load computer in Safe Mode and lower screen resolution.
Aug 10, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Mouse cursor dissapears
Might be a problem with the graphics driver, try updating the driver, or corrupt windows, the later is most unlikely.
Rifaa
Nov 06, 2008 | Acer X193W LCD Monitor
Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Feb 13, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Blank screen with cursor
MS-DOS edit command help This would bring up a blank edit screen, as long as the file is saved upon exit
Click on the above link , Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
