Question about Samsung PCN5425R 54" Rear Projection Television
Burnt smell blush picture
Picture went blush all of a sudden, slight hot burnt smell. Disconected power took back off, left projector very hot. get it fixed or buy new tv
  • 6 more comments
  • elric666 Dec 22, 2007
    after cooling down tv works great had it on for 4 hours today no problem. Seems that there is alot of heat coming from board that stk392-404 3-Channel Convergence Correction Circuit is on, if it is high voltage transfomer good quese at how much this would cost to replace would be nice. thanks
    Have disconnected convergence board from chassis and isolated. Five minutes after TV is turned on, heat sink connected to convergence board is hot enough that you cannot touch it for more than a few seconds.
    There are some plastic channel parts on chassis that heat sink was up against. This is where burning smell came from.
    TV seems to operate fine in this manner. Is heat sink supposed to be this hot?
    Convergence board was repaired 9 months ago by a professional...possible that it was put back without protection or shield to keep heat contained.
  • elric666 Jan 10, 2008
    replaced convergance board today,turned set on picture was very blue after about 2 minutes there was a sparking sound unplugged right away. plugged set back in while looking from back no pictue all lenes off there was a strong electric arck on board attached to the bottom off blue lens unplugged right away. next step waould be?
  • elric666 Jan 11, 2008
    the crt module under the blue lamp seems to be lose, disconected swings back and forth with just a little push
    the part that appears lose is wherer the crt joins the lens there is a conical piece facing down the crt swings freely at this point the red and green crt s are soildly fix at this point
    ok so I pulled the front of the tv off to get a better view of the crt. Looks like the crt is broken where it is attached to what i think is called the gun Glass is actually split, Think it might be time to consider new tv. Any idea how much a pro would charge Any idea what would have caused this to happen. can this crt still be holding a charge in its current state. did not get a spark when discharge voltmeter reads 0. If I desided to play with this for fun when could I get these parts. (Have to take it apart to get down the stairs anyway put on second story when I did addition before wall where closed in won't fit down stairs)
    P16LFM00BMB(TU)
    When convergance board was going out it was so hot could not touch heat sink,it is attached to fram right at blue lens connection witch was also very hot,am assuming if I try to fix this set I sould keep new convergance board could tube blowing30- 90 sec after I installed new board have damged board
    does the crt includ the yoke and board attached if not how does the crt conect disconnect I have out of tv and coolant drained coolent level was about 3/4 up view plud just a hair below breather hole
  • Samsung Master
  • 8,617 Answers
I would check your Blue crt socket for loose solder joints. Thats the board that plugs into the crt. I would also check the resistors near the convergence Ics heat sink either open or bad solder joints. Let me know what you find. Look over the solder joints with a magnifying glass and use a digital ohms meter to check resistors remove one lead from the circuit when you test the resistors your reading will be accurate that way.
Posted on Jan 11, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Jan 11, 2008
    Your lens assembly is evidently broke. Unless you feel comfortable discharging a CRT this is something that can be done if you proceed with Caution. The Crt Lead must stay in the crt (Red Lead) its discounted from the High Voltage block some have tabs that release this lead others are simply twisted and pulled out. Be sure to ground the lead to the Chassis to discharge the CRT THIS IS VERY CRITICAL DO NOT TOUCH THE LEAD END THAT CAME FROM THE HV BLOCK GROUND IT TO THE METAL CHASSIS FIRST. HIGH VOLTAGE WILL BE PRESENT. once its discharged proceed with removing the crt module, verticle and horizontal yoke wire clips from the chassis. Leave the yoke and purity rings on the crt just disconnect the wire clips where they attach to the chassis. There should be 4 screws that hold the lense assembly to the crt bloch. Remove them and carefully lift the crt up and out of its mount. You may want to cover the chassis incase of any leaking CRT coolant as this is highly corrosive to the circuits should any spill. Once you have the CRT out remove the plug and drain the coolant this contains Glycol so discard it accordingly. The lense assembly should also be attached with 4 screws usually spring loaded this is no doubt where your problem is at this junction. Proceed slowly, and let me know if you need me to clarify anything further.
  • Sonny Berry
    A pro would charge you probaly 400 to 600 to replace the blue tube. You could do this yourself. The new tube would be probaly 200 to 300 depending on where you purchase it from. Give me the number on the tube and I can get a lead on one if you would like. Yes the tube could still have voltage present the tube could have cracked due to heat, low coolant level etc. I would op to fix the set depending on what you could find a new CRT for.
  • Sonny Berry
    I would say that your new convergence board should be fine,as long as that didnt get extremely hot as those chips run fairly hot so you should be allright with the new board.
  • Sonny Berry
    The CRT Socket should just pull off from the end of the picture tube. Some have some epoxy holding it firm but the glob of epoxy is easily pulled off. No the yoke doesnt come with a new tube you will have to remove yours along with the purity rings. They have a screw that loosens them and they slide on. Some times the yoke is bonded but after releasing the screw clamp a firm twist will get it to slide off.
  • Samsung Master
  • 456 Answers
You need to change your power supply wire and check out that the wire is not open from inside circuit and it may be short circuit
Posted on Jan 10, 2008
    Genius:
  • 1,153 Answers
Maybe High Voltage Transformer, you can have a board replaced easier than buying a new set.
Posted on Dec 22, 2007
  • Lashawn Robinson Dec 22, 2007
    If heat is coming from convergence board and you know that is the smelling area then this will be the board to change, You will need model number and call to check, you can try PTS 18008447871
  • Lashawn Robinson Jan 11, 2008
    No the CRT is only the Glass part. The yoke has a part number and CRT board also.
Hi, LG 42" today started
you need to take rear cover off to inspect whats happened ..u will see or smell what gone wrong if done asap... UNPLUG FIRST ....
Feb 27, 2011 | LG Televison & Video
Daytek television will not turn on.
There is a manual switch on the bottom of the TV. Flick it on and TV screen should come on. The power light will come with this switch off but the screen won't. It had me cursing for a while until I saw the little switch.
May 15, 2010 | Televison & Video
There is a switch on the bottom of the unit that has to be turned on. The power light will come on but not the screen until the switch is on.
Mar 27, 2010 | Televison & Video
I start up my screen play 5000 and no startup menu appears or no picture, the lamp is working as the projection is white only. What is wrong. Regards: Shane Cook
The Projector was sitting unplugged for about a year, after having the projector plugged in for a while I disconected from the power for about a minut and then plugged the power back in.
I guess the battery within the Projector had no power.
Regards: Shane Cook
Jan 17, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have a 50803 projection tv. The picture went out. It started with a green tint and lines going across it. I turned off the tv and then turned it back on. Now there isn't any picture at all. There was...
This is very simple to repair if have burning parts smell,replaced parts that burning smell,the parts that cause by the burning smell part,make it to dies that hard to find.My sugestion replaced the DM power board,first to get power back,than go on from there.
Dec 12, 2009 | Mitsubishi VS-50803 50" Rear Projection...
My bulb went out on my infocus sp-4805. I bought a new bulb, and replaced it, and it worked...for five minutes. the picture went out, and it was overheated. I took some parts off, and sprayed can air in...
The fan is probably on it's way out and cannot produce enough air flow to cool the lamp. Replace the fan with the same ratings as the original and it should work fine. The only other thing would be a problem with the power supply not supplying enough power to the fan, but, a bad fan is more likely.
Feb 24, 2009 | InFocus ScreenPlay 4805 Multimedia...
Tv Philips Magnavox won't turn on
Its Broken And Now Dangerous i would not even try getting it fix. That burnt smell is never a good sign
Sep 07, 2008 | Televison & Video
No power in multimedia projector
is the lamp burnt out?
try it in another outlet?
smell the unit and see if anything smell burnt.
it could be the power supply in the unit as well causeing the issue if non of the leds are displaying as well. make sure all connections are tight as well.
hope this helps a bit.
Aug 02, 2008 | 3M MP 7740i Multimedia Projector
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
51 people viewed this question
Jerry Greenberg
Jerry Greenberg
