Question about Minolta Di3010 Copier
When paper is going into the paper feeder it is is getting wrinkled immediately and jamming the feeder
    Scholar:
  • 40 Answers
Sounds like someone got something stuck in the ADF (Auto Document feeder). See if it looks like the paper is really getting wrinkled up more on one end than the other and focus on that side of the feeder. I have seen post it notes cause this problem. People put in their originals and forget to remove post it notes before feeding the documents through. They come off and get stuck in the feeder. Without more detail it is hard to say what is stuck in there but it sounds like there is something impeeding the paper path. Shine a flashlight in there to see.
Posted on Oct 04, 2009
Why does my printer produce wrikled printouts
Your paper feeder is only working on one side causing the paper to try to go sideways. This will wrinkle the paper just like it is fed in crooked.
Jul 19, 2014 | Dell 1160w Mono Laser Printer
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
At power on, my bizhub 222 immediately gives me a paper jam error in the top feeder every time the machine is turned on.
If you have verified that there is no jammed paper, then I would suggest taking a can of compressed air and blowing the doc feeder out as best you can. Often times dust or paper scraps and debris can become lodged in the paper path, frequently blocking a sensor, thus creating a jam (despite the lack of paper.) As well, you might try running a thick piece of card stock through the feeder, as this will act to dislodge any stuck paper bits.
Let me know how it turns out.
David R.
Dec 09, 2010 | Konica Minolta Bizhub 222 Black and White...
Top feeder jam
Yes. When removing a jam, it is never wise to "aggressively" remove the paper, as it can break switches, gears, etc. maybe any switches or gears had damanged, need replacement of that parts.
Feb 25, 2010 | Samsung SCX4824FN Mono All-in-One Laser...
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Each time I print on plain paper the paper feeds into the machine and when it hits pinch rollers after the print head, the top right hand corner is turned over. Two pages later and the third page is so...
Follow these steps to reload paper:
  1. Flip the feeder guard forward.
  2. Remove the paper and make sure it's not curled or wrinkled.
  3. Fan the stack of paper to make sure the sheets are separated.
  4. Reload the paper against the right edge of the sheet feeder andslide the left edge guide against the other side, but not too tightly.
  5. Don't load paper above the arrow mark on the left edge guide.
  6. Make sure the printable side of the paper is facing up.
  7. Flip the feeder guard back.
  8. Once you have completed the steps above, press the cp_button_6.gif Start button.
Mar 07, 2009 | Office Equipment & Supplies
When the machine dont start fault error 102-353
Solution: Remove the Paper Jam in the Duplex Automatic Document Feeder (DADF) Top Left Cover bttn_print.gifMake Printable bttn_email.gifE-mail this page elem_1_spacer.gif
  1. Lift up the handle on the Left Cover of the DADF until the cover comes to a stop.
    NOTE: An inside cover will also raise with the Left Cover as the two covers are interlocked.
  2. Gently open the covers.
  3. Remove any paper that may be jammed. Check for obstructions in the DADF area including jammed originals, paper fragments, paper clips or staples.
  4. Check for obstructions in the DADF paper sensor area, small paper fragments, paper clips or staples may get caught there.
  5. Clean the DADF rollers with a damp cloth.
  6. Close the Left Cover on the DADF until you hear it click into place.
  7. Raise the DADF, remove all the originals, and then lower the DADF.
  8. Make sure your originals are not torn, wrinkled, or folded. Load your originals again following the instructions on the Touch Screen.
    NOTE: Originals that have already been scanned will automatically be skipped, and scanning will resume from the previous document sheet.
  9. Torn, wrinkled, or folded originals may cause paper jams and damage. Place the originals directly on the Document Glass to make new originals that can be scanned using the DADF.
Dec 29, 2008 | Xerox DocuColor 1632 Laser Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Paper Jam feeder
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Aug 14, 2008 | Dell 3100cn Laser Printer
Minolta Di3010 Copier Logo
166 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
