Question about Mitsubishi VS-50603 50" Rear Projection Television
Tv Audio & Video go off and by using remote channels or sound etc...back on
During the past week, the television came on normally for a few minutes to a few seconds and then Audio and Video go off like the set going on standby...screen is not totally off but no picture or sound...by flicking th remote to another channel everything comes back on normally and going back to the previous channel all is well...and then in a few seconds to a few minutes the cycle starts all over again...
  • Mitsubishi Master
  • 8,617 Answers
Sounds like a solder problem where the tuner attaches to the chassis. Or possibly a weak capacitor in the video circuit. If youd like a service manual for the set let me know . I know where to send you to get it for 10.99. Hope this helps
Posted on Jan 16, 2008
How do I to set my TV to channel 3 using a universal remote?
If you have the set to a video input use the source or input button to change to tuner. If the remote is programmed to the set enter directly for example 03 and enter.
If set goes to 3 and no signal disconnect set and a box if used from power for several minutes. Power back and see what you have.
A simple test of the set is see if A DVD etc connected to one of the rear audio/video inputs works normally--this will rule some things in or out.
Dec 20, 2012 | Televison & Video
Turning on tv
how about using the local channel does it works normal?
Jul 18, 2012 | Televison & Video
We have had for the past few weeks a large black rectangle appear mid-screen. It happens on a few stations only (6-8-20 etc) and appears to be only a problem mid to late afternoon. Also it never happens...
Sounds like you have your closed captioning turned on. The TV remote may have a CC button on it, if not it will be in the TV menu. Try turning this to OFF. What you are describing may be the TEXT 1, 2, 3, or 4 function of this feature.
Mar 15, 2010 | Televison & Video
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No sound
have you check with other input like a vcr?...good luck
Aug 10, 2006 | RCA F32649 32" TV
Tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
Televison & Video Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
