Question about Grohe Aquatower 3000 Shower Tower Handshower Panel
Have a jacquizzi shower tower not getting enough hot water, just warm. hoses seem to be fine. think it may be the thermostatic regulator? can I fix or adjust that myself?
    President:
  • 3,433 Answers
Sounds like a regulator and yes, most regulators are adjustable..It's either that or a bypass valve.
Posted on Oct 04, 2009
98 grand cherokee little heat.heater hoses hot top rad warm bottom is cold collant barely luke warm
While it doesn't seem likely, if you've changed, or had the thermostat changed.... I'd say you got a faulty thermostat. I am curious as to what your temperature gauge says the temperature of the engine and coolant is.. If your gauge is showing hot, I can think of two more possibilities... the water pump isn't pumping right... and, if the water pump isn't working right, the problem can be a cracked head or block, which can cause an airlock in the coolant system. Check the coolant or radiator cap.
Nov 14, 2013 | 1998 Jeep Grand Cherokee
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
Loud vibrating sound coming from hot water heater. Had gas company change meter and regulator. At first was losing hot water while in the shower. Went through check list after it coded out at #12, all...
Can't address other issues, but WATER pressure should be 40 to 80(I'd say 70)lbs. tester at home D for $10-15. Goes on hose Bibb outside, or at washing machine cold valve.
Mar 18, 2017 | Rinnai Water Heaters
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
Water from my shower tower is not hot enough. I have hot water flowing from taps all around the house. Only lukewarm water from my shower tower. What is the problem?
what brand of shower handles do you have and do you have just 1 temp handle or is it separate hot and cold?
Nov 17, 2010 | Home
I can't seem to find the thermostat in my 2000 Chrysler LHS 3.5 L Is it in the manifold at the end of the upper radiator hose or elsewhere? I've seen so many answers and haven't yet found a solution. A...
If you were to take the upper radiator hose off the engine, and look into the resultant hole, you would see the thermostat.
The thermostat on all cars blocks water leaving the engine and going to the radiator, until the thermostat warms up enough to open.
While the thermostat is closed, water circulates through the heater hose, straight back to the inlet of the water pump. This circulation prevents hot spots, distributing the heat evenly to warm the engine up, and also brings that warmed water to the thermostat.
When the t-stat gets hot enough to open, water leaves the engine instead of circulating through it, and that allows cool(ed) water to flow from the radiator through the bottom hose to replace the water that left through the upper hose and t-stat.
The stub that the upper hose attaches to on the engine should be part of a small housing that is bolted to the engine. Removing that housing is how you remove the t-stat.
Aug 05, 2010 | 2000 Chrysler LHS
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Grohe Aquatower 3000 Shower Tower Handshower Panel Logo
127 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
