Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Frigidaire dishwashers FDB2810LDC0 bottom of door leaking where do I find a new seal?
    Sergeant:
    Champion:
  • 382 Answers
Try an appliance parts and repair store the door seal is not hard to replace just phone a couple of places and give them make model and year of machine they should be able to help you
Posted on Jan 09, 2010
    Scholar:
  • 30 Answers
You can obtain a new seal through an appliance parts store. You will need the make and model number of your dishwasher to get the correct seal.
Posted on Oct 04, 2009
Water leaking during cycle
Good Morning Susan Hanley, thank you for your post!
From what you are describing it could be a possible problem with the gaskets for your Frigidaire dishwasher. Where is the leak coming from? If it is coming from the door it could be one of the door seals not sealing properly. Check the seals to make sure that they are not out of place.
If the leak is from the bottom of the dishwasher it could be a loose hose or drain pump issue. You may need to have a technician come out to your home to properly diagnosis and repair your dishwasher. I hope this is helpfully. -Matt
Oct 28, 2014 | Frigidaire Dishwashers
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
Frigidaire built in dishwasher leaking water out of the bottom.
One of the reasons could be door seal or sump seal leaking. But if the leak only occurs at a particular time in the cycle then most likely the wash motor or drain motor seals.
Need the model number to make a more closer assessment.
Dec 31, 2012 | Frigidaire Dishwashers
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Door of dishwasher is leaking at bottom left corner.
HI. the door seal has been compromised. it could be simply farad or slightly propped open by some sort of debris as well. check the door seal for faults. replace if faults are found.
Also, make sure the door isn't mis-aligned. this will happen over time during heavy usage. re align the door if necessary.
Sep 22, 2009 | Frigidaire Dishwashers
Water leaking on the floor at the door.
frigidaire models usually leak water at the top of the door and water enters in the door through door latch.2 fix this u can insert a double sided sticking tape behind the tub seal at the top so that door top sits tight against the top part of seal.
also u can remove the front door panel 2 c if water ia jumping out of tub at the bottom at lhs and rhs corners.if thats the case pull out the door seal and insert it back stretching it little bit and leaving some of it extended at both bottom corners so that it can stop the water from splashing out.
Aug 15, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire Model FDB2810ldc0 s/n:TH43526319
Dishwasher is leaking water from underneath during the rinse cycle and a small drip during the wash cycle
Sep 22, 2008 | Dishwashers
Frigidaire Dishwasher leaking but not from door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Jun 30, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
160 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
