Question about NEC MultiSync LCD1830 18.1" LCD Monitor
Backlight does not light
After we drove this monitor 100 miles, it no longer has a working light. how can I determine if the fault lies with the inverter or with the bulb itself? would you please email me your answer at roger@rogergrafstein.com. I asked a question earlier and something came back in a file format that my PC can't handle. thanks in advance, roger
  • 13 more comments
  • RGrafstein Dec 27, 2007
    Thanks for your interest and prompt reply. I have already turned it on and off several times. I don't understand what you mean by "make sure it gets enough power. The monitor worked until it was transported 100 miles to a new location and now the screen is black but using a flashlight I have determined that its getting the signal from my PC.
    Seems to me that its most likely a failed inverter or failed bulb. do you agree? how can I test for which one of these parts is at fault?
    Now that I have the whole thing taken apart, I want to be able to inspect the bulb in order to rule-out or rule-in that part. I think I could check the continuity in the bulb if I find it and if the filament appears intact.
    If the bulb tests out OK, I would think its the inverter that's at fault.
    Thanks in advance for your reply, Roger
    As stated in my earlier posts, this NEC monitor has a black screen, even though the green light is on and I can see my PC desktop image in the monitor by using a flashlight. I read on line that the inverter often fails on these. I have disassembled that monitor to the point where I could replace the inverter ($70), BUT what if its just a problem of a burnt-out backlight bulb? How do I find that bulb in order to inspect it and check continuity? (I currently have all the printed circuit boards exposed, but I haven't tried to get any further into the innards without good guidance.
    Thanks in advance for you help, Roger
    So far two different "experts" have provided me with absolutely no help at all! I need an expert who can follow my train of thought, which I have layed out in detail in my previous posts. And I need an expert who is really familiar with LCD monitors, like those made by NEC. Please help,
    Roger
    Skippy, I'm home again and I could work with you anytime in the next hour and a half (to 11:30 PST) if it would be convenient for you. If not, could we do it any time after 10 hours from now (8 a.m. PST).
    I tried a suggestion from the previous expert to check for inverter's high voltage output and there seems to be none at all. so I guess its either a fuse, like you suggested or some problem in the powersupply to the inverter. I looked over the printed circuit boards for a loose wire or plug and found none.
    I'll try to add an image - monitor innards - to this posting.
    thanks,
    roger
    here it is.
    Thanks for you continued interest. I see white and pink wire, But there is a pair of these at Each of the two ends of this board (is this the inverter?). Also each pink wire has a black wire with it (smaller size than the pink wire) and each white wire has a smaller white wire running side-by-side with it. I am assuming that each set of pink/black/whhite/white wires goes to a different bulb.
    I think I see the transformers that you refer to: there is one near each end and they are the biggest components on the board (they are each numbered 0053 1711S). Have I got it right so far?
    Now, I don't recognize any other transformers and I don't see anythings that look like yellow or orange fuses. Please send me more detailed instructions on how to find them.
    let me know if it would help for me to send a more detailed photo of one end of the inverter.
    I found on fuse marked F1 right next to a little (1/4 " tall) can marked *1UY 330 16V. (the * stands for a tiny box at the beginning of the part number.) Resistance measures 0.0!
    Is there a second F1 fuse that I need to find and check? I can't seem to find it.
    I didn't mention this before, but maybe it will be helpful. I found that the inverter IS getting power from the main board. there are 7 terminals where 6 blue wires and one white connect to the middle of the inverter. I touched a few of them with my voltmeter and read 12v in some cases and something less than that in other cases. Let me know if you want me to do more measuring there.
    (by the way, when I tried to find a high voltage output from the inverter, I used the contact points on the inboard sides of the two ivory colored connectors at each end.
    I'm sorry to be so dense or blind. Still can't find it. I have to leave now for dentist appt. When I return, I will post a photo that shows the "other side" of the board in detail. thanks for your patience, Roger
  • RGrafstein Dec 28, 2007
    1. I found an F1 in the upper right, but I can't find the second F1. Can you point it out to me please? Thanks, Roger
    here's the middle board
    1. here's 3rd board
    Skippy101 I'm counting on you to guide me to a solution to my problem! Please don 't let me down!
    I believe the log of some previous monitor problem troubleshooting that you just posted is useless to me.
    What I need from you at this point, in order to follow through with your promising ideas earlier today:
    1) Are you certain that my inverter has a 2nd fuse labeled F1?
    2) If so, exactly where is it? (could it be mis-labeled on my board?)
    2.5) If not, what do I do next?
    3) If I do find the other F1 and it's resistance is greater than zero, what would the solution be?
    4) If its resistance does = zero, what would I do next?
    5) why did you ask me to post photos of the other two boards?
    We both have put in a lot of time on this. Hours. Will you stick with me and see this thing through?
    Roger
    p.s. if you need me to measure any voltages or resistances, just tell me where.
    If we can be SURE that the entire problem is located on the inverter board, then I would spend the $70 for a new one and just replace the one thats there. If I was retired, I might want to get a tiny soldering iron and multimeter w/ diode checker; but I'm not retired yet. Actually, my son is paying me to fix his monitor and he doesn't want to spend much over $100.
    Also, I don't see any "brown" or "burnt" areas on the inverter board.
    So, are you sure its an inverter board problem? Why do you think so? are there any other simple tests we can do to confirm that and also that the bulbs are OK and that the other two boards are working well?
    I very much appreciate your time. I'm going to bed now, but look forward to seeing your reply in the morning. Good night, Roger
    Brigadier General:
  • 6,966 Answers
If I may add:
1. Your PC & display are both OK;
2. You need to determine which is at fault, the CCFLamp or the Inverter:
2.1 If the inverter is working, you would be able to read a high frequency high voltage at the terminal connector that goes to the lamp, if yes then it is the lamp (use a DVM set to AC 1K);
2.2 If no, then you need to check if the inverter is getting +12. If yes, inverter is defective, if no then power supply is in question.
Offhand, I would suspect simply a loose connection somewhere (considering that it was transported. Wiggle all connectors to make sure they are snug and tight.). The next suspect would be the lamp. They have a tendency to burn their ends/connectors or develop corrosion over time which would manifest when jarred.
Hope that this be of additional help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 27, 2007
  • Louie  Role
    Louie Role Dec 27, 2007
    Hi again,
    A friendly reminder pls., the inverter's output as said is high freq/high v, it has a tendency to arc across terminals or test prod. Please exercise extreme care. It is almost like a miniaturized FBT of a CRT monitor.
    Cheers.
  • 143 Answers
Sorry you are having this trouble these lcd monitors when you can still see your desck top but no light comes on then you might have blown a fuse inside the monitor the inverter is fine you have problems in the dc to ac converter in the monitor it self . how long have you had this monitor. you can take it apart and check for your self it is very easy all lcds no mater how big or small have a ac-dc converter in them small serface mount fuses that look like resistors go out also bad connections . when you take it apart you will see that the lamps are built in to the screen it is more costly to replace the lamps than to replace the monitor. get back to me and ill give you step by step to find the fusess. good luck
  • 6 more comments
  • marco amezcua
    marco amezcua Dec 27, 2007
    ok on theboard that is to the most left if you are looking at your screen you will see were the lamps connect to the board it should be a pink and white wire andthere will be 4 sets next to them you will see on each side two trans formers small ones next to them you will see on each side one small orange looking or yellowish looking resistor this is a fuse messure it with a dvm or digital volt meter in ohms it should read 0 ohms if anything else it is bad replace it it should be like 1.5amp or 2amp fusse this will fix your problem
  • marco amezcua
    the fusses im talking about should be labled f1right next to the trans formers
  • marco amezcua
    you will havanother fuse on the other side looks just like the first one you checked
  • marco amezcua
    marco amezcua Dec 28, 2007
    that is a great pic can you post all three boards like that make sure they are complete k thanks
  • marco amezcua
    Symptom: Backlight flashes short after start and then shut down.
    I've invested several hours:
    power board
    - checked out power supply capacitors
    - fuse 25V / 2.5A
    inverterboard
    - replaced C11 and C12 = 180nF / 250V
    - check fuse F1
    When the monitor was warm > 25° - it works
    Next day - dark screen.
    replaced the whole inverter board --> the same
    Then I found your schematic:
    CN1 / 7: 250 Hz square 8Vss = duty cycle for brightness
    The protection circuit causes shut down the backlight.
    Each lamp connector CN2 – CN5 has a feedback with a rectifier. The DC voltage is measured above C13, C22, C24 and C25 and should be about 5V.
    The comparator U1C and U1D compare this voltage against 1.55V (Pin 8,10 – C16).
    The feedback of CN5.2 ( C25) had only 1V in cold condition. So the backlight shut down.
    Next try only with power OFF / ON.
    I change the connector CN5 and CN4 and also CN2 an CN3 – oh, oh – this fault moves to C24.
    Okay, the backlight has a little problem. This is okay, because it has plenty of hours on duty every working day the last five years.
    Change R28 from 680Ohm to 1kOhm, and increase C16 from 1µF to 220µF
    Now the backlight turns on for 10sec. ignoring the protection circuit.
    Backlight warm up and turns to normal operation.
    Attention: This modification is no general repairing method for the dark backlight.
    You’ve carefully checkout the behaviour with an oscilloscope before your change the components. Check the power consumption on the 12V CN1 / 1 (1.2A @brightness=50%; 2.2A @ brightness= 100%).
    In case of disabling the protection circuit even for 10 seconds you might destroy the power circuit or the high voltage inverter.
    This case: more or less weakness of the backlight bulb.
  • marco amezcua
    i found that at one of my sister sites good luck
  • marco amezcua
    yes i will help you ok looks like there is only one fuse hummm ok on that long board that the bulbs plug into you will see that the board gets discolored like a brown this is were most of the heat is generated do you have good soldering skills here we go solder all the conections around that look brown next we are going to check some transistors do you have a volt meter that has diode checker you will need this ok when you are ready let me know k
  • marco amezcua
    marco amezcua Dec 29, 2007
    ok so i did more research on this and found that on this model if the fuse is still goog remove the skinny board flip it around and solder any connections that might look bad loose or that might have gotten hot check all transistors with a dvm and solder them as well if you find one that might be shorted from emitter to collector or to base then replace this will be time consumming for beginers you might wat to replace the board yes this is your problemthe little board or inverter sorry i didnt get back to you sooner just want this to be right foryou good luck my freind and feel free to call on me any time
  • 790 Answers
Hey
Your guess is right its the back light bulb which has gone wrong ... And as i know warranty covers for the back light too which u can get replaced free of cost ...
    Sergeant:
    Champion:
  • 209 Answers
I'm not sure but maybe try ..turning it on and off a couple times, make sure it gets enough power.
Did the monitor work before ?
are you hooking it up to your pc or as a tv ?
  • 1 more comment
  • Simon Zwaan
    Simon Zwaan Dec 27, 2007
    I thought the problem may lie in how many other devices are plugged in the same outlet.
    It sounds like you know your way around Tv's. so yes, i would recommend seeing if the filament in the bulb is still intact, since this would be easier[make sure you unplug it though :p]
  • Simon Zwaan
    Can you see the bulb ? and see if its intact still ?
    maybe you can test it somehow...but dont turn the tv on with some parts removed, that will most likely burn some fuses.
  • Simon Zwaan
    I would say contact support and get them to repair it, they should do it for free if its under warranty.
    and if you complain enough they might do it cheap to keep their good name.
    That's all I got, sorry
    hope it helped.
No display
This could be many things
Check all connections.
try a different known-good monitor with same video source (computer), if the second works then the fault lies in first monitor.
If the second monitor does not appear to work, the fault lies with your video source (computer).
In the former case, check power is going to the original monitor. Is the power light coming on ?
Without further information, it not possible to say much more
8.March.2015
Jan 23, 2015 | Computers & Internet
I have a 2004 Yukon denali and while driving, I got check gas cap alarm. 2 miles later check engine light is on. Checked gas cap, cleaned gasket and tightened. Drove for 2 days. Reset fault and drove 160...
Hello, have you tried to unhook the negative side of the battery for about 10 minutes and then go from there . It should reset the computer completely .
Sep 14, 2011 | 2003 GMC Yukon Denali
Monitor shuts down about 5 seconds after turning it on .
I have been looking at a Dell E228WFP with the same fault as previous posters on this forum. It works for a few minutes and then the back light turns off. With the PCBs out of the case it runs for a little longer. Applying heat to the inverter board using a hair dryer causes it to turn off in about 5 seconds.
If you are after a quick test to see if your monitor is suffering from the R821 'resistor problem' then simply remove R820 (labelled 564), power up the monitor and heat the inverter board with the hair dryer. If it no longer turns off then R821 is probably your problem. I have shown the relevant section of the schematic below.
I have not had a chance to make appropriate measurements to determine a suitable replacement value for R821. Reducing it from 1M to 560K or 470K will certainly lower the error voltage being fed back to IC801. If anyone wanted to determine a suitable value empirically then I would suggest replacing R821 with a 470K resistor in series with a small 500K preset and determining the highest value that allows it to operate correctly when heated. I would then back this value off by about 10% and fit the nearest fixed value 0603 SMT resistor.
I have now carried out the above and R821 needs to be 470k to ensure reliable operation. If I had more time I would look into why this change is required....
Jan 31, 2011 | Dell E228WFP Monitor
Monitor shows picture then goes black, if you hold light to screen you can see picture
Sounds like your backlight has gone faulty, this is a pretty easy repair, however it can be either the inverter, the power supply, or the lamp itself. You really need a service manual, to see how to do it and troubleshoot, exactly locate your fault. Otherwise,all one can do, is swap out, know good for bad, starting with the Power Supply, and working back, as if PSU isn't working 100% nothing else can do.
May 08, 2010 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
BLANK SCREEN MAYBE THE VGA CARD? pLEASE HELP
Hi first thing to do here is to see where the problem lies. use a vga / monitor lead from your laptop to an external monitor or lcd/plasma tv in pc mode and by pressing fn and your monitor switch key think its f5 you should be able to determine if your screen is at fault, a common problem is the screens inverter or backlight bulb, if you manage to get an image on your external source then you its sure to be screen related wether it be the inverter/backlight/or even your internal screen lead this process can save money and time, you would then need to test the inverter to see if its this, the inverter is normally the cheaper option as the backlight can be a long tricky process.
I hope this has helped please rate :)
Feb 23, 2010 | HP Compaq Presario CQ50-110US Laptop
Dell monitor 15 inch the green light stays on but no picture
It's the backlight supply tripping out from backlight failure, but the thing still stays on. I got it to act right by switching to factory presets with some fast menu action once, but the general solution is going to involve tricking the backlight into staying on; you can look at the thing in bright ambient light to see that the display is still working, but of course without a backlight it's pretty much useless.
Since $100 buys a better and more efficient monitor, just replace it; otherwise of course you can either replace the backlight (or go for one of the projector mods) or convince its drive circuit to put up with it a bit longer. I spotted a bad capacitor but swapping that out hasn't gone well yet....
Mar 14, 2009 | Dell E153FP 15" LCD Monitor
MY ACER LAPTOP SCREEN TURNS ON BUT THE SCREEN IS BLACK
To determine if you have a video card problem or the LCD screen is at fault.
Connect an external monitor to the video port on the laptop and boot up your laptop, if you get a display on the external monitor then your video card is OK and you have a faulty LCD.
When you power your laptop without an external monitor and have a close look at the LCD screen at and you see a slight image then the fault is with the backlighting panel. This fault could be a faulty inverter or a faulty CCFL backlight lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
The inverter can be easily replaced so can the CCFL lamp (but requires a lot more work)
For info on parts and repair service goto www.lcdparts.net
Mar 02, 2009 | Acer Aspire 5610-4648 Notebook
MY LAPTOP SCREEN IS GONE BLANK...I CAN CONNECT IT TO AN EXTERNAL MONITOR BUT THE DISPLY ON THE LAPTOP SCREEN IS REALLY DIM...WAT SHOULD I DO? I TREID ADJUSTING SETTINGS ON THE LAPTOP BUT NOTHING WORKS..THE...
hi, i have had the privilege of work on these particular series of HP Laptops. This may sound daft, but have you tried the brightness keys? If so you have a fault with the backlight which is caused by 1) a fault on the Mainboard 2) the inverter has blown (a small circuit board the regulates the voltage from main board to the lcd screen) 3) The backlight on the lcd screen has blown. You will need to determine where the fault lies before paying out large sums. You may want to get a diagnostic done by a Local laptop company. Hope this helps.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
Emachine laptop shut down without warning
Test your monitor. To do this, you will need another monitor.
Plug in any desktop monitor to the output port on the back of the laptop. Restart the laptop.
If you are able to use the laptop using this other monitor, then your problem lies in a part called a video power inverter.
It is possible that it could be the lcd backlight, but that is doubtful.
The power inverter is available at many online markets for a relatively small cost. Installation is generally easy enough that any person with reasonable mechanical skills and a set of small screwdrivers can do it.
I once walked an 11 year old boy through the process from 1200 miles away over the telephone.
good luck
tony
Jan 21, 2009 | E-Machines M2350 Notebook
NEC MultiSync LCD1830 18.1" LCD Monitor Logo
459 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
