Question about Dryers
The dryer just quit working. The last item dried in their was a pair of tennis shoes. Next day it won't even turn on. Checked the thermal fuse and jumped it but it still would not start, spin, etc. Help!
    Sergeant:
  • 186 Answers
This may not be a solution but try testing the outlet its pluged into or the circuit breaker at the main box. Stranger things have happened.
Posted on Oct 03, 2009
Lg gas dryer wont restart I dried 4 pair tennies in it must of shDLG2302w gas dryer down over load ? wont restart light in dryer comes on though
There is a thermal fuse in the blower housing tht is bad.. what makes it blow the fuse is a clogged dryer vent.. after u replace tht fuse make sure your vent is cleaned out. wht happens is the unit over heats and then blows the fuse..
Nov 25, 2012 | Dryers
Our 8 year old kenmore dryer won't do anything when you press the start button. We don't hear even a hum. It worked one day and then just wouldn't start the next day. We checked the fuse box...
Here is a good link for basic troubleshooting... But 10 to one the culprit is a thermal fuse or thermal cut off.... they are usually pretty cheap and easy to replace....
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
One final note on these: if you find your thermal fuse\cut off (or element) open, before replacing it, be sure to check the airflow out your dryer's vent system. Even though these devices do 'wear out' with age, poor airflow's the #1 cause of failure of these devices, and if your vent's partially clogged, a new thermal won't last very long, but will do its job again, and leave you 'cold' (a new element won't last long if the vent's clogged, either).
More info and pics:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Jun 16, 2011 | Kenmore Dryers
Whirlpool duet dryer GEW9200L will turn on but will only "click" when push button in. Timer light starts flashing. Wife was drying a load of towels with her pair of tennis shoes in it on the last load that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Dryers
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 01, 2010 | LG DLE2532W Electric Dryer
Dryer won't start. was drying a load and had a pair of tennis shoes in with the clothes. It stopped and now won't start back up. All lights, beeps etc. seem to work fine just won't start.
As silly as this seems, did you make sure the door is completely closed. This is a common problem when drying tennis shoes. One time when I was living in an apt. complex, I went to check on my laundry, and my shoes were lying on the floor (with a couple of other fabrics). I then stood by and watched the remainder of the cycle, and next thing you know - the door opens up and throws out my shoes. Never would've believed it unless I seen it with my own eyes. I would turn everything off, and then go through your regular routine. If this doesn't work, feel free to contact me - and we can go to Plan B...:) Good Luck to you, Jim
Mar 29, 2010 | Kenmore Elite 21082
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer will not come on when temp is selected and button is pushed
You have a bad thermal fuse. Take back off. There are two different types. One type is round and looks like other pieces in the back only smaller. It has two wires. The other is 1/2" wide and 2" long with one screw, also with two wires. You can test either one you have by first unplugging the machine, Connecting the two wires running to the piece together. Tape them so they will not touch metal. Now plug machine in and try. It should heat. DO NOT CONTINUE TO OPERATE MACHINE WITH PART BYPASSED This is a high limit safety. It keeps the machine from overheating. If left bypassed it will catch fire. You will also need a cycling thermostat. Kits are sold with both parts inside. The cycling thermostat not working caused the machine to cycle on the thermal fuse until it went out.
Please rate solution
Aug 26, 2009 | Whirlpool Dryers
Dryer won't start
fuse ,,fuse ,, fuse.that has to be replaced.
Mar 02, 2009 | Roper RES7646KQ Electric Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Dryers Logo
Top Dryers Experts
