Question about Sony Televison & Video
TV-sony KV-1985MT..dead set
Any help??sony tv .the supply for horizontal driver transistor is zero volt.but when i disolder the 5 volts supply for system control...the set run.(but of coarse since no supply for system contol the control disabled.).
any help?
4 Suggested Answers
SOURCE: Got picture but no sound for Model no:KV-1985MT
if useing an sd video cable you must also connect the audio cable or cables.
Posted on Jun 08, 2007
  • 275 Answers
SOURCE: sony tv H.O.T
Yup. Can be replaced with a simple BU 208D
Posted on Apr 09, 2008
romsky79
  • 822 Answers
SOURCE: sony tv KV-27FS120, blinks 6 times, horizontal transistor is good, and driver to, can you help me?
check the memory.
Posted on May 31, 2009
It wont turn on it blinks 7 times can i fix this
Hi there.
In sony tv`s the seven blinks code(sony error codes)usually indicates a high voltage shutdown(t.v has exceeded 33k volts). That is often caused by the power supply regulation and/or horizontal circuit fault.
Hope this help Merry Christmas
Dec 19, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Apr 15, 2009 | Televison & Video
Sony KV-27S42 no sound and audio blinks four times
+13 & -13 requires for Vertical Deflection IC and produced by Flyback Transformer, these volts will be produced IF Horizontal deflection circuit works properly. so try to check H-Out Transistor and its necessary volts / signal. Pls also mention correct Model Number to provide you more help.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No power.
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Aug 23, 2007 | Sony KV-32V35 TV
Sony KV-32S40
When the horizontal output (2SC4927) is shorted it means one of 2 things is wrong - the horizontal drive transformer has cracked solder joints or the flyback transformer is shorted inside. If the solder joints on the horizontal drive transformer (the small grey transformer connected to the base of the horizontal output transistor) are cracked then the set will play for a little while and then the parts you just replaced will again be destroyed. ALWAYS resolder the driver transformer when replacing the parts you mentioned! When I replace the parts you mention and I do not see any obvious cracks on the driver transformer then I unsolder the B+ pin of the flyback (labeled 135, for 135 volts) and put a 60 to 100 watt lightbulb (drop-light) in series with the flyback. This means that the 135 volts B+ goes through the lightbulb and then into the flyback, so the lightbulb acts as a current limiter to protect the horizontal output. When you turn the set on the bulb should glow no more than about half bright and you should hear the high voltage come up, but you should not see a picture. If you turn the set on and the bulb glows as bright as if it was plugged into the wall then you can bet that flyback is shorted and must be replaced.
Jul 12, 2007 | Sony KV-32S40 32" TV
Jun 08, 2007 | Sony KV-20V80 20" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
TV power supply problem
.01 mf 2000 volt. in flyback circuit .it is a timing capacitor. the red high voltage block is bad and that took out the capacitor. also check the horizontal output transistor...it is probably shorted.
Aug 25, 2006 | Sony KV-27V26 27" TV
Televison & Video Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
