Just bought a Nikon D40 Camera and sometimes when I view pictures that have been taken, the pictures get distorted. Is this common or and easy fix. dee
Your pictures are most probably distorted because of camera shake. If you invest in a Nikon lens with VR = vibration reduction or a Sigma hsm os = optical stabilization, this will allow you to shoot at slower speeds and will reduce camera shake.
The most obvious problem will be shooting in low light conditions without vr or os...this will give blurred images.You will need to up the iso and shutter speed with a wide aperture to achieve more stable images. Bear in mind, when you raise the iso, you will get noiser images and the Nikon D40 does not handle noise very well - but can be eliminated with software. Hope this helps.
I am having a problem with my lens. When it tries to focus it makes an awful noise and the camera...
(More)
I am having a problem with my lens. When it tries to focus it makes an awful noise and the camera will not take a picture because lens will not focus
shutter jaming on auto intermittent - - or after pushing the take button - the shutter doesn't...
(More)
shutter jaming on auto intermittent - - or after pushing the take button - the shutter doesn't operate. then 2 minutes later it will be ok
I have the nikom ML-L3 for my Nikon D40 and can't find instructions on how to make it work on my...
(More)
I have the nikom ML-L3 for my Nikon D40 and can't find instructions on how to make it work on my camera
I'm trying to remove the battery chamber cover on a Nikon D40, the solution for the D40x does not...
(More)
I'm trying to remove the battery chamber cover on a Nikon D40, the solution for the D40x does not seem to work
