Question about Olevia Kolin DLT2711M 27 in. LCD Television
Kolin (Olevia) DLT 3212M, On Screen Display Locked out
We have a Kolin (Olevia) DLT 3212M. We are having problems with our TV's On Screen Display (OSD). When we push the menu button on the remote, it takes us to the OSD as usual, but Auto Setting under Video is locked out, and the Colour of the picture on all channels is not sharp and accurate. also, all of our settings that are on a number scale (Brightness, Hue, Sharpness, Saturation and Contrast) are locked in place, and we cannot ajust those as well. Brightness and Contrast are stuck at 50, Saturation is stuck at 16, Hue is stuck at 1 and the Sharpness is stuck at 168 (the scale should only go from 1 - 100). Does anyone know how to unlock these settings
SOURCE: Cannot Control Picture Settings?
I have the same exact problem. It just shut off and when I turned it back on, I couldn't adjust any of the picture settings. After a day or so everything was all well again until I tried to adjust the picture and it went back to a dark screen. I was told by Olevia that my Mainboard needs to be replaced and it costs ~$202!! I can replace it myself but come on, why am I spending all this money just to pay for a "Windows" crash?
Posted on Aug 23, 2007
SOURCE: unlock Olevia remote control
Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
Posted on Jan 28, 2009
SOURCE: FOGGY-HAZY PICTURE
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Posted on Apr 21, 2009
saidneurot
  • 128 Answers
SOURCE: Olevia LT220TB whole screen is full of a pattern, no auto search
this maybe a case of the board check this with a tech guy and after if you need the part check this web site http://www.discount-merchant.com
regards
Posted on Dec 18, 2009
Testimonial: "Thanks for the suggestion."
SOURCE: cannot adjust the color, brightness, contrast etc, using my olevia remote
how to set TV from High Def to Standard Def TV .. olevia
Posted on Mar 16, 2010
I am asking for the code of kolin tv for chunglap remote controler thank you.
0281,0288,0285. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 09, 2014 | Olevia Kolin DLT2711M 27 in. LCD...
Why did my Kolin DLT-3212M LCD tv picture suddenly go green
Are you connected with a box of some kind via the component input on this set? (red, green, blue connections?
If so unplug that box and wait--plug it back to see if the box will reboot and correct the issue--also you can try to swap green cable itself with blue for example and if then have BLUE issue that cable is bad.
May 20, 2012 | Televison & Video
I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
Apr 23, 2010 | Olevia Kolin DLT2711M 27 in. LCD...
My LCD screen went of but there still sounds coming out
you have to check the back light off your lcd replace the inverter or capacitor in the power module
Jul 16, 2009 | Olevia Kolin DLT2711M 27 in. LCD...
Kolin PT-501
you used a spherical bulb, this TV needs a bulb with a parabolic reflector.
Jun 03, 2009 | Olevia Kolin DLT2711M 27 in. LCD...
Olevia Kolin PT-501 LCOS TV Screen remains black and lights flutuate
I have the same TV and had the exact same problem. I had to replace the lamp and power supply in mine to get it to work. Unfortunately...its next to impossible to find the parts, at least the power supply. I found the lamp online and I was lucky to get the online store I purchased the TV from to send me a power supply from one of thier stocked models, but only after I turned them into the FTC Consumer Protection. The TV was sold to me as a closeout but new, as it turned out the tv was a refurb, thats the only way I could get the parts I needed.
Hope this helps and if you need any other information please let me know.
T
Nov 07, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
Kolin PT-501 LCD/LCOS HDTV, rear projection TV
Well i really do not know what that is but i do have a thought it could be a bad connector and if you want i have the same tv for sale for $300 shipped just for parts the problem with my pt501 was the screen turned colors but the lamp is in excellent shape and so is the lcos screen the ownly thing that does not work is the main board (ciruit board) i will send you the hole thing for just 300$ shipped if you'd like email me back giovani.rivera@yahoo.com
Jun 29, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
KOLIN TV - Snap sound and went dead
The number is 1-888-796-8298,you need your model and serial number,tell them what happened and they will tell you where to take it.You should have some warranty.
Oct 03, 2006 | Olevia Kolin DLT2711M 27 in. LCD...
Olevia Kolin DLT2711M 27 in. LCD Television Logo
109 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
