Question about Acer Computers & Internet
My screen wont come on until about 2 hours after turned on, moniter is an acerAl1716B
  • 146 Answers
Have you tried a general reset ? or unplugging it and plugging it back after a few minutes ?
Otherwise this sounds a lot like a power supply problem.
Posted on Oct 04, 2009
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Damaged screen so i plugged in a moniter but now windows wont operate properly.and the screen on the moniter wont load fast enough to launch safe mode or factory reset should i reinstall windows by making...
LOL a Recovery CD should be made when you first purchased the system. Now that you have it all bugged up, I would doubt that a Recovery CD you make now would even work. Most times the ones you make anyway don't work.
I think you should turn off the laptop, turn it on and immediately start hitting F8 repeatedly to get into Safe Mode. I've never heard of a situation where the monitor wont load fast enough to launch safe mode.
If that's the case it sounds like you need to fix the problem with the laptops lcd screen.
What do you mean when you say windows wont operate properly? I think you've got viruses or infections that you need to get rid of.
Apr 26, 2012 | Dell Latitude D520 Notebook
Accer asspire 5535 screen wont lite up but works with external moniter
so you had a new inverter put in, are you talking about the actual backlight? can you see anything on the screen at all? point a flashlight at the screen when it's turn on and try and look from different angles to see if you can see anything on the screen. you can also take the screen off and check the connection to the actual LCD.
Jan 27, 2012 | Acer Aspire 5535-5050 Notebook
Ok so i change T.V.s for a week. Wen i changed it wont turn on until like 30min. Now i changed it again and hasnt turned for like 2 hours. HELP ME =(
set your ps3 on standby mode(solid red light), then just hold the power until the screen turns on. if the system turns off, try again. keep on trying until it works. it should beep 3 times to signal that it's on, then 1 more time to signal you did it right.
Jun 04, 2009 | Microsoft Xbox 360 Console
On button is orange and moniter wont come on
If the PC is on and running and the light is oragne it means your video card is bad or the cable is loose.
Power off your PC (gonna have to hold the button down on PC until it turns off) and then turn off the monitor.
Reseat cables on both ends from Monitor and PC then power back on again and see if that helps.
If it still doesn't work you have a bad video card.
Hope this helps
TankMurdock
Apr 24, 2009 | X2Gen MG19VT 19" LCD Monitor
My sansa fuze wont turn on and ive checked to see it has enough power (its been charging for 2 hours) and it still wont turn on it is just a plain black screen.
i had the same problem try resetting it by slideing the power switch to the on position and hold it there for 10 to 30 seconds until it turns on then let go. that should sove you'r problem
Jan 15, 2009 | SanDisk Sansa Fuze MP3 Player
Laptop screen
Have you tried hooking up an external moniter? If so do you have video on that moniter? If you do have video on the external moniter then you most likely have a bad inverter or a bad lcd panel.I would replace the inverter first because it's not very expensive.If that doesn't work then you can replace the lcd panelAnd if that doesn't work you have problems at the system board level.
Dec 15, 2008 | Compaq Presario M2000 Notebook
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Computers & Internet Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
