Question about Dell Computers & Internet
Horizontal Line running down my Laptop Computer Screen
I have a Dell Inspiron 1720 Laptop Computer and I have a thin dark blue horizontal line running right down the middle of my screen. Is there a way to fix this without having to buy a new computer screen? (This happened once before and I fixed it but I forgot how!)
  • 2,229 Answers
You can try changing resolution to something else and then back.
You can see if your colors are 32-bit.
The fact that you "fixed" it is probably an coincidence. Once you start getting anomalies like that, it usually means a new screen.
Posted on Oct 04, 2009
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
I have a thin horizontal line across my dell latitude laptop screen
If the thin line is always there, you have a set of pixels burned out. This usually occures vertically. There is easy fix, except to replace the screen. If the laptop is under warrenty, contact the manufacture for repair options.
Sorry could not be something easier for you.
Mar 19, 2012 | Dell Latitude D630 Notebook
Very thin black line runs across the screen 1" up
that is either a dead pixel or a failing horizontal filter. it is caused by hardware faults. nothing you can do to prevent it.
Feb 18, 2018 | Dell Inspiron 1721 (dndwna2_5) AMD Turion...
Inspiron 1525 horizontal lines missing
You can try to uninstall and reinstall the video driver in dev manager. try to check if this happens in bios aswell if it does then it may be the lcd itself.You can contact the manufacturer to have the lcd replaced if your computer is still under warranty.hope this helps...
May 23, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
The monitor in my computer turns dark when i turn the laptop on
That sounds like you have something loose ..
Here is an on-line service manual for that
I would look specifically @ the LCD/monitor lead and its connections
Jan 01, 2009 | Dell Inspiron 6400 Notebook
A horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Dec 23, 2008 | Computers & Internet
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
Jun 28, 2008 | Dell XPS M1330 Laptop
Dell Inspiron sudden horizontal line
Not that I've ever heard of, Usually that kind of issue is caused by blunt force trauma to the lid of your laptop......
Oct 04, 2007 | Dell Inspiron 710m Notebook
Computers & Internet Logo
424 people viewed this question
Alun Cox
