Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
Maytag Refrigerator MFC2061HES - temperature control
Lost temperaure control in the main part, while the freezer is working well. Repairman guesses that the controller is to be replaced
  • 833 Answers
Maybe. Is the compressor staying on? If it is...then the temp controller may need to be replaced. If it is cycling regularly, then you are iced up and the controller can't do much to help you. Fully defrost. Takes 2 days to melt it all. Then let's see where we are.
Posted on Dec 23, 2007
Freezer works, fridge warm
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Maytag MFC2061HES Stainless Steel French...
Refrigerator not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hkare
May 25, 2010 | Maytag MFC2061HES Stainless Steel French...
Not making ice - water still works in refrigerator
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Apr 21, 2010 | Maytag MFC2061HES Stainless Steel French...
I cannot change the temperature on my Maytag MFC2061HES. Whenever I try to change either the refer or freezer temp, it creeps back down to 33 with the freezer going to 6. I cannot turn it off. The...
It sounds like your fridge has problem with the damper stuck open. The damper is in the top-back-center of the fresh food section. I can't tell by the pics I have how to get to it, but looks like it's simple to get to it - just remove the damper cover.
Check the damper for the ice buildup. Clean if needed. Unplug the fridge and check continuity on damper motor. Replace damper if no continuity.
Check the microswitch on the damper assembly. C on switch [where it connects to black wire] should make contact with NC [yellow/red] when button is not pressed, and C with NO [blue/red] should make contact when button is down).
With temp in the fresh food section so low, the damper should be closed, and if it isn't there should be power (110v ac) coming to the motor either continuously until it closes or for a short period of time within a few minutes after you try to set the temperature, can't tell by schematic. Unplug, connect your DMM in "volts ac" parallel to the damper motor (red and green/yellow wires), and plug fridge back in. If it does not show 110v immediately, set the DMM to show the maximum voltage registered, and leave in the fridge for 20-30 minutes, with doors closed. If there was 110v, and the damper is still open - replace damper. Otherwise it's very likely that the control board failed.
Parts:
Damper assembly: 67003903
Control board: 12782036SP
If you order from that site, use "New10" coupon code for 10% off.
Oct 25, 2009 | Maytag MFC2061HES Stainless Steel French...
Maytag MFC2061HES Not cooling Either Fridge or Freezer
Replace the relay on the compressor and it should start working.
Jan 12, 2009 | Maytag MFC2061HES Stainless Steel French...
Maytag MSD2657HES Refrigerator Side by Side
The air that cools the refrigerator section comes from the freezer. The refrigerator temperature control controls the run cycle. You may have to replace or have the thermostat replaced. The temperature control has failed.
Jul 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
160 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
