Question about GE JGRS14 Gas Single Oven
Hooked up gas stove and fire want go out when cut off.
Just hooked up gas range and every thing works but the fire want go off when it is put in off position. Is the fire suppose to burn continuously?
  • 725 Answers
NO - the fire is supposed to go out! Your gas valve is bad and if you'll give us a call asap, we'll make sure you get the correct part to replace. Call us at 972-859-0929 and let us ship this part to you. We look forward to working with you! Have a great day!
Posted on Oct 05, 2009
No stove wires hooked up to neutral
The older electric hookups for ranges used only the 2 hot wires and a ground. Somewhere on the range the neutral and the ground should be connected together. This connection is no longer accepted by the National Electrical Code, but no one is going to force you to change the wiring unless you change the range.
Where is the ground wire attached? Some ranges had a metal jumper to connect the neutral to the ground. Your oven element is 240 volt only. It does not need a neutral. The ground/neutral wire is for some of the controls and the clock.
Aug 13, 2015 | Kenmore Stove / Oven / Range Bake Element...
I would like to remove the fuses that control the stove top on my Maytag oven so that i can use only the oven. ( i do not need to use the burners and do want to risk turning on the range top because i...
Hello, there no such thing as a fuse to control the top burns, if your Maytag is gas or electric.
The gas goes through a regulator to keep the range gas pressure @ 2lb. Then gas goes into aluminum manifold system for the top burners where each burners has a fuel valve in the manifold. Off of this manifold is another aluminum pipe with a little adjustment valve for the setting the flame on the oven burner in the oven.
Mama, it sound really dangerous with you stacking things on top of your kitchen range. Even when the oven is on it will vent hot oven air in the back of the top of range. Are you familiar with the Fire Triangle. Fire...needs three things, fuel, air, and ignition to burn. I hate to say it, but you have all three of these component to have fire in your home. By stacking things on top of your kitchen range.
Now, just a little word of advise here. DO NOT STACK STUFF ON or NEAR your kitchen stove, heater for you home or even around light bulbs and power cords. Ms. it seems that you are a very intelligent young lady. Just remember the FIRE-TRAIANGLE----it could possibly safe your live and home. I wish you many years in your life experience through time. God Bless...stewbison
walk gently up on this earth, and she will be good to you....
Sep 08, 2011 | Ovens
Cant get oven to turn on. the only thing that works is the stove top n have to light it my self. My electical screen wont turn on which controls my oven
Check and see if the stove is plugged in. I suspect your DSI module has failed.
All these stoves ain't the same nor do they even work on the same principle. I am guessing from the picture you have a DSI system. For a more precise answer always post a mdle number. Most model numbers are posted on the oven frame of the lower drawer.
Here is your DSI service Manual
Dec 21, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven only works when house is cold
all gas range ignitors have to be just hot enough. i would say put an amp clamp meter on it. if it draws over 2.8 amps its probably good. if under that its bad and replace it.
Aug 01, 2010 | Brown Stove Works TTM721-DK Gas Single...
No gas to the oven, range works fine
This video shows where the lever is
Mar 06, 2010 | Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Mounting a microwave above stove
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top. Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above). Venting (outside ot inside), and attaching method. Though they're simple in concept to install, it's a bit awkward in reality. The main thing you need to determine is sufficient space between the MW and the stove. You will have to check, but I believe you need 18" beneath the microwave. Many companies have brackets for that purpose.
Jul 15, 2008 | Frigidaire FGB24S5A Gas Single Oven
GE JGRS14 Gas Single Oven Logo
110 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
