Question about Swisher Sp - 38 38" Sweeper
Why do the wheels seem to stick - Swisher Sp - 38 38" Sweeper
Toro snowblower powermax 1028 Starts fine was working well but shifting seemed stiff and after getting stiffer it seemed stuck in low reverse. Any ideas of cause?
Sounds like the Friction wheel is sticking on a rusty shaft.
Stand machine up on it's Chute then take the Bottom cover off.
See how the Friction Wheel should move on the aluminum looking plate. That shaft needs to be clean and slightly greased.
Dec 23, 2013 | Garden
Steering wheel problem (sticking)
No there are not electrical or electronic problem. Just mechanic problem.
you must test all the steering system for many problem, oil, vibration, etc. Go to some repair shop and get some Result for fix it.
God bless you
Jun 30, 2012 | 2003 BMW Z4
Rear wheels not spinning. Front wheels spin when in 4 drive.
Hi First of all check the adjustment on the rear wheel thats sticking sometimes the brake pad comes away from the metal it is fixed to this maybe the case on your vehicle, the make & year of vehicle would help further but I a sure you got something to check now. Please leave me feedback, Malcolm Campbell.
Sep 23, 2017 | 1994 GMC Sierra
2002 kia sportage 2wd brakes sticking
hi check all your brake linnings for contamination especially brake fluid on the linnings if this is ok you have a build up of pressure if its possible for you drive till the brakes start to lock up get out go to each wheel see if any of them is getting hot if so the problem is on that wheel jack it up to see if the wheel is locking if its red hot it will be sticking then try the rest of the wheels one at a time jack them up see if its one wheel or all if its one wheel release the bleed nut on that wheel see if it releases if it does it must be fitted with a pressure regulator to that wheel replace it . now if its all wheels its more likely to be the brake master cylinder or if fitted pressure regulator that supplies all the wheels a long shot i cannot see but better to mention it the brake pedal is not sticking and holding down yates210456
Sep 29, 2008 | 2002 Kia Sportage
Front wheel of vibe stroller sticks when turning.
exactly the saem problem with mine. Di you find a solution yet?
Sep 24, 2008 | Regal Lager Phil & Ted Vibe Jogger
Roaring Noise
check the mounts for the shock absorbers
Jun 01, 2008 | 2002 Kia Spectra
Swisher Sp - 38 38" Sweeper Logo
23 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
