Question about LG WM1814CW Front Load Washer
The rubber on the washer is getting this sand-like film on it. Why am i getting this?
    Sergeant:
  • 233 Answers
If there is sand or sand-like sediment in the washer and it did not arrive there from any item(s) washed in it prior, it arrived via the water supply. This means it came from either the water supply or from the pipes in the house, if the pipes are corroded old steel or iron pipes. If it came from the water supply and/or the piping system and other water using appliances. Check the aerators on the sink faucets and inside the toilet tank. If any of those locations have the same problem, it may be the water supply or the water piping system. In those cases, other major problems exist, which will not resolve the washer problems.
Some of that "grit" may actually be coming from your washing detergents. Try running a cycle through with hot water only.
Then make sure the seals are clean. Try another load and see if the symptoms return.
Posted on Oct 05, 2009
Can I clean the film off my headlights
Yes, use a hairdryer to heat the film up then peel it off!
Jan 24, 2015 | Cars & Trucks
Tip
Stop Washing Machine Smell, Mold, and Mildew
Your washer is not smelling so clean and you wonder first why it is like this and then how can I fix it?
With the popularity of the front load washer and the low water usage associated with then comes other problems. Because of the low water consumption the dirt grime and residue that would normally be totally washed away, some is left as a film in the washer. Cold water usage can contribute to this by adding to this film. The make up of certain commercial fabric softeners and detergents can make the problem worse by giving the bugs food. Animal fats in some products are great food for the molds and mildew.
Some washers also let a bit of water lay in them after the wash this gives moisture which also helps to grow molds and mildew. When you close the door tightly after washing, this traps all the water in the washer and prevents the rubber door gasket, the soap dispenser, and other parts of the washer from drying out.
Here are some things you can do to prevent these problems.
Always leave the door to your washer open after use.
Leave the dispenser drawer open also.
Use liquid detergents instead of powdered, they will leave less film
Use the minimum detergent possible to get your clothes clean, more is not always better.
Use fabric softener sheets in your dryer instead of the washer liquid.
Check that ALL clothing is removed from the washer.
Periodically wipe down the rubber door gasket and check for mold or stuck socks
Use hot water when practical, like when washing whites. This will help remove the film.
If you have a problem here is what you can do to help fix it.
Wipe everything down with a solution of vinegar water.
Pour vinegar into the dispenser drawers. Then add ½ cup of vinegar to your washer and run through a clean cycle with hot water.
You can periodically add the vinegar to your wash load to help keep things under control. This will naturally disinfect and clean your washer while you are doing your regular wash. This is especially good to use if you will not be using your washer for a few days again. The residue of vinegar in the washer will help to control the smell and mold formation.
If you are buying a new washer, do some research before buying. Some machines are more prone to this problem then others. A bit of research may help you to aoivd the headaches of having a washer with this problem.
on Jan 28, 2010 | Washing Machines
The water continues to run into the tub. It even run with the power unpluged!
The fill valve sound like it has gotten some sand or the rubber seal has cracked. The fill valve will need to be replaced or cleaned. The valve is on the back of the washer right where the Washer hoses hook up to the washer.
Mar 20, 2011 | Washing Machines
How can i clean the rubber seal on the door
Get some very coarse sand paper and rub hard on the seal, this should remove the worst of the residue
Nov 12, 2010 | Tricity Bendix AW1000W Front Load Washer
I have a leak in my above ground sand filter, model 140. the leak is around the drain. How can I fix it? It is a Hayward, high rate sand filter, GM series, model 140ab. Thank you
Usually in th bottom of the filter you have two parts. The first is a piece with a screen that threads into the plastic housing. The second is a Cap with a rubber washer inside. Make sure the rubber washer is there. Do not overtighten the drain into the houseing
Jul 24, 2010 | Hayward Pro Series 18" Above Ground Pool...
Have a 70cc dirtbike with a mikuni carb. Only way the engine will continue to run is if the choke is completely on. Even after complete warmup, the minute u start to take it off choke it stalls. Put the...
Hi and welcome to FixYa,
Almost always, the described problem indicates a clogged idle jet. Fix calls for a carb pulldown, cleaning and soaking of non-rubber parts in carb cleaner. A can of compressed air would be helpful in blowing sand, dirt, grit and varnish like film off the components. Exercise care and caution on the small springs, washers, spacers and o-rings. If the air idle mix screw would be removed, count the number of turns from fully in.
Good luck and thank you for asking FixYa.
Jan 05, 2010 | 2006 KTM 125 EXC
Changing the sanding drum cant get it on the rubber drum
have same problem. take retianing screw and washer off, remove from arbor and roll the rubber between fingers with a mashing force. this can take a little bit but i ussualy only have this problem when i dont loosen the set screw and dont use it for awhile.
Oct 12, 2009 | Dremel 300-N/55 300 Series Tool Kit
It seems the sanding table has frozen to the eccentric on my orbital clarke floor sander. Any recommendation on how to get apart. I need to replace the 4 upper bolts with rubber washers. I have tried...
Go to Americansanders.com and under the orbital sander click on it and the manual is 38 pages long, the parts explosion is towards the back of the manual but it should show you how to disassemble this tool so you can get to the bolts that you need. Let me know if you need more help
Sep 30, 2009 | Clarke Floor Sander Floor Sander Orbital...
Seems to be clogged and will not drain a bath mat's bottom surrface completely crumbled into a sand like mixture
Your strainer's likely plugged with the "sand". Locate your dtrainer, situated between the drum and pump, and connected to the drum with a rubber hose. Clean and reinstall it. Get all of the sand out, and remove any that you can see laying in the pump cavity, etc. Run an empty load to flush the machine. This may have to also be done a second time if there is a lot of residue.
--W/D--
Aug 18, 2009 | Fisher and Paykel IWL12 Top Load Washer
Our Cuisinat dcc200 leaks water all over the counter.
This is most likely a result of a defective washer stopper in the reservoir. I took mine apart by gently pulling the rubber washer over the top of the plastic loaded holder. I lightly sanded it with 220 grit paper until it was smooth and replaced it.. No leaks so far.
I cannot find the replacement washer. It appears the Cuisinart only offers the entire reservoir as a replacement part and that costs about $40 ... Thanks a lot (all for a 99 cents rubber washer.) :-(
Jun 07, 2009 | Cuisinart DCC-2000
LG WM1814CW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
