Question about Dell Computers & Internet
I need to simulate a floppy drive on my hdd to run a Dell bios upgrade
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
Http://chitchat.at.infoseek.co.jp/vmware/vfd.html#top
Posted on Oct 07, 2009
Desktop wont boot past floppy disk seek failure
There is a menu in the BIOS (set-up) menu that disables the floppy drive. This option enables or disables the floppy drive.
Aug 15, 2012 | Dell Computers & Internet
I can't find the bios flash instructions .how do you flash the bios on my toshiba a35s159
You should check the Toshiba WEB site for instructions to how to upgrade (flash) your BIOS, if you make a mistake you may not be able to repair or recover from your mistake.
I have done BIOS upgrades on a few computers.
If your Toshiba has a floppy drive and you can boot up from this floppy drive then the BIOS upgrade needs to be downloaded to a boot floppy. Then boot up from this floppy and run the BIOS upgrade program. When completed, remove the floppy disk and boot up your laptop.
YOU MUST CHECK THE TOSHIBA WEB SITE AS THESE INSTRUCTION MAY NOT BE APPLICABLE FOR YOUR TOSHIBA LAPTOP.
Jun 02, 2012 | Toshiba Computers & Internet
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
I have an optiplex gx150 pIII, with a floppy drive. I downloaded the set up floppy so I could do a new install. after running the floppy disk, the messages says hit enter to continue. I place the xp sp2...
You don't need the install floppy... hit the F12 key when booting and you will get a boot order selection and tell it to boot to the CD. If it still doesn't see the HDD then you are most likely having a disk read problem with your hard drive. If that is the case you should boot into the system BIOS and see if the HDD is recognized there.
Apr 01, 2010 | Dell OptiPlex GX150 PC Desktop
Dell Dimension E520 problems Hello I have a Dell Dimension E520 PC. It boots up from the Floppy drive instead of the Hard Drive. I have changed the BIOS setting by disabling the floppy and have tried to...
In this case First Need to check in HDD Power is working perfectly or not then check Data calble is perfectly attached or not both side HDD and Mother board then check BIOS Setting and change settign boot piority make first boot from HDD
Mar 17, 2010 | Computers & Internet
Dell disk drive not working
check bios if fdd is detected.
tried any other fd.
replace floppy disk drive.
wait? is this disk drive like floppy or the HDD?
Oct 07, 2009 | Dell Latitude D520 Battery PC Notebook
Unable to boot to anything external.
Save yourself some trouble. Pull a CD/DVD drive out of another computer or just buy one. They are very cheap. Connect the CD/DVD drive to the server and install the OS as usual.
If you are lucky WS2008 will already have a compatible SCSI/RAID driver. Otherwise, you will need to press F6 and install the driver from the floppy.
If this helps please vote for my solution.
Sep 07, 2009 | Dell PowerEdge 2600 Server
Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Jul 09, 2009 | Dell Optiplex GX50 Intel Desktop PC -...
Trying to upgrade RAM
These are the exact specs for the memory that will work in your machine.
Note: I am not affiliated with this vendor in any way, it's for illustrative purposes only.
Feb 25, 2009 | Dell Optiplex GX260 Desktop PC - Intel P4...
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Computers & Internet Logo
603 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
