Question about HP Pavilion A1245C Athlon 64 3700+ DVD+RW MiniTower (Open Box Product, Limited Availability, No Back O... (EG137AARABAOB) PC Desktop
Wont come on
Has long beep - four seconds-long beep -four seconds-long beep-etc.---l
  • 523 Answers
One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard / Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
Posted on Oct 04, 2009
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
03 Buick Regal wont stop beeping, now my car wont start! HELP!
Ok, first off do you have a chiped key? look on the side for a resistor symbl if yes try a spare key if you have one. secondly is the theft light flashing? third option turn the key to the on position wait 15 and try to start the car, if it is your security system this will sometimes deactivate it
Apr 30, 2013 | 2003 Buick Regal
First four lights on cycle indicator flash and machine beeps 10 times and then beeps every 30 seconds
I recomend checking drain hose for kinks or obstructions and checking drain pump. most dishwashers will drain first for about 25/30 seconds.Also check the drain hose into the main plumbing connection it maybe blocked.If it cant drain it wont do anything hope this helps.
Feb 17, 2012 | KitchenAid Dishwashers
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
I have a compaq r4000 cto. I just replaced the system board with a used board. When I first started it up I got a black screen and three beeps which after a few tries became a black screen and four...
It's unlikely that you have 2 or more defective memory modules. Remove all cards such as video, modem, etc. Also disconnect all drives (hard drive, CD, DVD). Try booting with one memory module at a time. If still a no go then I would suspect the motherboard.
Feb 20, 2011 | HP Compaq Presario R4000 Notebook
My acer computer wont turn on it just beeps about every 5 seconds.
Those are beep codes-- for a hardware issue- I need to know the BIOS manufacturer and the exact code of the beeps--1-1-2 or 1long-2 short etc----also be sure all chips are seated correctly and nothing has changed since it last worked
Jan 18, 2011 | Acer Aspire One AOA150-1784 Netbook
Computer wont start and i get a series of four
4 beeps mean your th'ers something wrong with your computer's memory. Make sure that the chips are seated firmly in their sockets If that dont help pull out the chips and reseat the chips
Hope this helps.
Sep 28, 2009 | HP Compaq dc5700 Small Form Factor -...
Clio radio just beeps at me+wont accept code!
enter the radio code by pushing buttons 1,2,3,4 on the radio and then push button 6 to confirm the code
if code is 3756 you sohuld push button 1 for 3 times, button 2 for 7 times...and then button 6 for few seconds
May 13, 2009 | 2000 Renault 181
Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Feb 01, 2009 | Dell Dimension 4700 PC Desktop
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
Sep 16, 2008 | HP Compaq d530c PC Desktop
Computers & Internet Logo
482 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
